Comware
  • 1.  HPE 5710 not working ACl
    Posted May 18, 2023 03:49 AM
    I have an ACL 3000 configured on my switch. I need to block all traffic from other VLANs to the 192.168.1.0/24 subnet (VLAN1). However, I also need to allow one IP address from another VLAN to connect to a host in VLAN 1. So, I added rule 1 to the ACL, but it doesn't seem to be working as the host still cannot ping. The ACL is configured as an inbound rule. Can you please help me with this issue?
    description AdvVlan1Only
    rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
    rule 1 permit ip source 17.0.0.5 0 destination 192.168.1.91 0
    rule 5 deny ip
    Thank you!
  • 2.  RE: HPE 5710 not working ACl
    Posted May 18, 2023 05:55 AM
    Hi!
    The first thing you need to keep in mind is that ACLs are not stateful, e.g. you need to explicitly allow traffic in BOTH directions in order to have a two way communication between desired hosts.
    The second thing that may surprise you if you don't have any previous experience with Comware 7 - an ACL applied to a Vlan-interface by default affects both switched and routed traffic in the respective VLAN. This can be changed with the command "packet-filter filter route" (under the Vlan-interface context), but the default setting is "packet-filter filter all":
    Parameters:
    route: Filters packets forwarded at Layer 3 by the VLAN interface.
    all: Filters all packets, including packets forwarded at Layer 3 by the VLAN interface and packets forwarded at Layer 2 by the physical ports associated with the VLAN interface.
    Ivan Bondar
  • 3.  RE: HPE 5710 not working ACl
    Posted May 19, 2023 04:03 AM
    Edited by spgsitsupport May 19, 2023 10:48 AM
    Used VLANs in existence:
    10.10.x.x various subnet mask
    Default VLAN 1 (still some hosts in it)
    10.0.x.x 255.255.0.0
    I use this setup for every VLAN (~ 30, on 5900AF, Comware 7) and have no issues
    interface Vlan-interface14
     ip address 10.10.14.254 255.255.255.0
     packet-filter 3014 inbound
     dhcp select relay
     dhcp relay information enable
     dhcp relay server-address 10.10.9.1
     dhcp relay server-address 10.10.9.25
     acl number 3014 "Switches VLAN restrictions"
      #rule 0 permit udp source 10.10.14.0 0.0.0.255 destination-port range bootps bootpc
      #rule 0 comment "Allow DHCP requests" # commented out so no requests allowed!
      rule 2 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.3 0.0.0.0
      rule 2 comment "Allow SINGLE management workstation 1 access TO ALL devices on VLAN14"
      rule 3 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.99 0.0.0.0
      rule 3 comment "Allow SINGLE management workstation 2 access TO ALL devices on VLAN14"
      rule 5 permit udp source 10.10.14.0 0.0.0.255 destination-port eq dns
      rule 5 comment "Allow DNS queries BY ALL devices on VLAN14"
      rule 6 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.131 0.0.0.0
      rule 6 comment "Allow Radius Server 1 access BY ALL devices on VLAN14"
      rule 7 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.128 0.0.0.0
      rule 7 comment "Allow Radius Server 2 access BY ALL devices on VLAN14"
      rule 8 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.27 0.0.0.0
      rule 8 comment "Allow Kiwi Server access BY ALL devices on VLAN14"
     rule 9 permit ip source 10.10.14.0 0.0.0.255 destination 10.10.9.40 0.0.0.0
     rule 9 comment "Allow HP IMC Server access BY ALL devices on VLAN14"
     rule 16 deny ip source 10.10.14.0 0.0.0.255 destination 10.10.0.0 0.0.255.255
     rule 16 comment "Deny VLAN14 to ANY 10.10.x.x VLAN traffic BY ALL devices on VLAN14"
     rule 17 deny ip source 10.10.14.0 0.0.0.255 destination 10.0.0.0 0.0.255.255
     rule 17 comment "Deny VLAN14 to Default 10.0.x.x VLAN traffic BY ALL devices on VLAN14"
     rule 20 permit ip
    Ofcourse (these are different VLANs), you can restrict to specified ports)
     rule 11 permit tcp source 10.10.120.0 0.0.3.255 destination 10.10.22.1 0 destination-port eq www
     rule 12 permit tcp source 10.10.120.0 0.0.3.255 destination 10.10.22.1 0 destination-port eq 443
    With these ACL rules I never needed both ways exceptions because in both above cases only first VLAN from each pair (14 -- 9 or 120 -- 22) is fully isolated
    When BOTH VLANs are isolated, then ofcourse one has to have rules in ACLs for inbound in two separate ACLs applied to inbound for each VLAN interface
    acl number 3025 "Access Control VLAN restrictions"
     rule 8 permit ip source 10.10.25.0 0.0.0.255 destination 10.10.26.0 0.0.0.255
     rule 8 comment "Allow VLAN25 access to VLAN26"
    acl number 3026 "CCTV VLAN restrictions"
     rule 10 permit ip source 10.10.26.0 0.0.0.255 destination 10.10.25.0 0.0.0.255
     rule 10 comment "Allow VLAN26 access to VLAN25"
    spgsitsupport
