Comware
  • 1.  HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 01:39 AM
    Hi Team,
                   We have recently power on the HPE 5900 switch and found the issue that Fan direction fault. Could you sugest on this..Please refer the  below Disply power and display Fan output command output..Please suggest on this..
    [HPE]display power
    Slot 1:
    Input Power: 117(W)
    PowerID State Mode Current(A) Voltage(V) Power(W)
    1 Normal AC -- -- --
    2 Normal AC -- -- --
    [HPE]dis
    [HPE]display fan
    Slot 1:
    Fan 1:
    State : FanDirectionFault
    Airflow Direction: Port-to-power
    Prefer Airflow Direction: Power-to-port
    Fan 2:
  • 2.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 01:58 AM
    Hi @Muthukumar1
    system-view
    fan prefer-direction slot <slot_number> port-to-power
  • 3.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 02:32 AM
    Hi team,
              Thanks for your suggestion and get back to you if any challenges on this.
    Muthukumar
  • 4.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 02:41 AM
    It will work. If any challenges, try to start your research here - https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00037014en_us , Page 151.
    In general do not underestimate usefulness of HPE support portal - https://support.hpe.com/hpesc/public/home It contains all the documentation for our products and many articles for configuration and troubleshooting. Questions like this one about preferred direction of fans could be successfuly self-resolved in 5 minutes using that amazing tool.
  • 5.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 03:27 AM
    Hi team,
                  sorry for the inconvenience if any woundable questions.
    Regards
    Muthukumar
  • 6.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 14, 2020 03:32 AM
    Hi @Muthukumar1 !
    You are very welcomed to ask ANY questions you want and we are always happy to help you. I am just trying to give you very handy tools to improve resolution time as 5 mins reading instead of hours waiting for the answer on forum may save you a lot of time.
  • 7.  RE: HPE 5900 switch FAN direction fault
    Posted Oct 15, 2020 06:07 AM
    HI Ivan,
    Thansk for your support and after confiured the commands as per you suggestion, now Fan status is fine.
     i am in struggling on Firmware ugradation and requesting you could you suggest the issue as well. Firmware upgradation as a seperate dicussion..Please response my discussion.
    Muthukumar
