Comware
  • 1.  HPE 5940 and SFP+ problem
    Posted May 09, 2019 06:18 AM
    Hi
    I have a problem with a new HPE 5940 4 slot Switch and the SFP+ , situation:
    - a new HPE 5940 4 slot, with a JH181A module (24 port  SFP+ and 2 porta QSFP+)
    - some JD094B SFP+ transceivers
    Installed and powered up the 5940, configured trough console connection fan trays, VLANS, and some others  basic function: all went fine.
    Well, when I insert a JD094B SFP+ tranceiver in a SFP+ port no link or led blink, nothing; on CLI "display interface ten-gigabit n/n/n" port report the SFP+ is recognized but interface status is DOWN, here complete, whith or without multimode FO plugged):
    [HPE]display interface Ten-GigabitEthernet 1/2/24
    Ten-GigabitEthernet1/2/24
    Current state: DOWN
    Line protocol state: DOWN
    IP packet frame type: Ethernet II, hardware address: ec9b-8bc9-909d
    Description: Ten-GigabitEthernet1/2/24 Interface
    Bandwidth: 10000000 kbps
    Loopback is not set
    Media type is optical fiber, port hardware type is 10G_BASE_LR_SFP
    Unknown-speed mode, full-duplex mode
    Link speed type is autonegotiation, link duplex type is force link
    Flow-control is not enabled
    Maximum frame length: 10000
    Allow jumbo frames to pass
    Broadcast max-ratio: 100%
    Multicast max-ratio: 100%
    Unicast max-ratio: 100%
    PVID: 1
    MDI type: Automdix
    Port link-type: Trunk
    VLAN Passing: 1(default vlan), 100-102, 104, 130
    VLAN permitted: 1(default vlan), 100-102, 104, 130
    Trunk port encapsulation: IEEE 802.1q
    Port priority: 0
    Last link flapping: Never
    Last clearing of counters: Never
    Peak input rate: 0 bytes/sec, at 2011-01-02 04:26:02
    Peak output rate: 0 bytes/sec, at 2011-01-02 04:26:02
    Last 300 second input: 0 packets/sec 0 bytes/sec -%
    Last 300 second output: 0 packets/sec 0 bytes/sec -%
    Input (total): 0 packets, 0 bytes
    0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses
    Input (normal): 0 packets, - bytes
    Input: 0 input errors, 0 runts, 0 giants, 0 throttles
    0 CRC, 0 frame, - overruns, 0 aborts
    - ignored, - parity errors
    Output (total): 0 packets, 0 bytes
    Output (normal): 0 packets, - bytes
    Output: 0 output errors, - underruns, - buffer failures
    0 aborts, 0 deferred, 0 collisions, 0 late collisions
    0 lost carrier, - no carrier
    [HPE]
    Other:
    - When I insert the SFP+ tranciever there is no visible laser TX output.
    - no difference with or without multimode FO plugged in the tranceiver.
    it almost seems that the ttranceiver needs to be activated... or so
    Any suggestions? What can I do?
    Thank's
    B.
  • 2.  RE: HPE 5940 and SFP+ problem
    Posted May 09, 2019 11:49 AM
    You can review the information with the following commands:
    display transceiver alarm interface ten-gigabitethernet 1/2/24
    display transceiver diagnosis interface ten-gigabitethernet 1/2/24
    display transceiver manuinfo interface ten-gigabitethernet 1/2/24
    Laser safety
    WARNING!
    Do not stare into any fiber port when the switch has power. The laser light emitted from the optical
    fiber might hurt your eyes.
  • 3.  RE: HPE 5940 and SFP+ problem
    Posted May 09, 2019 07:09 PM
    Hello, I have a JH181A mac Sec plugin module in my FF5940 2-slot and also have installed JD094B with a SMF LC connected to another JD094B in a JH181A in another FF5940 4-slot.   The link is up.  The JD092B transceivers also work.
    What version of Comware do you have installed ?    You should have a Comware version R2612P02.
    [40MKA2S]show transceiver interface Ten-GigabitEthernet 1/1/3
    Ten-GigabitEthernet1/1/3 transceiver information:
    Transceiver Type : 10G_BASE_LR_SFP
    Connector Type : LC
    Wavelength(nm) : 1310
    Transfer Distance(km) : 10(SMF)
    Digital Diagnostic Monitoring : YES
    Vendor Name : HPE
    Ordering Name : JD094B
    [40MKA2S]
    Connector Type : LC
    Vendor Name : HPE
    [40MKA2S]show interface eten
    [40MKA2S]show interface ten
    [40MKA2S]show interface Ten-GigabitEthernet 1/1/3
    Current state: UP
    Line protocol state: UP
    IP packet frame type: Ethernet II, hardware address: d894-0322-1df3
    Description: Ten-GigabitEthernet1/1/3 Interface
    Loopback is not set
    10Gbps-speed mode, full-duplex mode
    Link speed type is autonegotiation, link duplex type is autonegotiation
    PVID: 1001
    MDI type: Automdix
    Port link-type: Hybrid
    Tagged VLANs: 4004
    Untagged VLANs: 1001
    Port priority: 0
    Last link flapping: 1 hours 1 minutes 33 seconds
    Peak input rate: 15 bytes/sec, at 2019-05-09 18:09:02
    Peak output rate: 46 bytes/sec, at 2010-12-31 19:06:34
    Last 300 second input: 0 packets/sec 13 bytes/sec 0%
    Last 300 second output: 0 packets/sec 13 bytes/sec 0%
    Input (total): 133 packets, 51568 bytes
    0 unicasts, 0 broadcasts, 133 multicasts, 0 pauses
    Input (normal): 133 packets, - bytes
    Output (total): 296 packets, 62341 bytes
    0 unicasts, 0 broadcasts, 296 multicasts, 0 pauses
    Output (normal): 296 packets, - bytes
    [40MKA2S]
  • 4.  RE: HPE 5940 and SFP+ problem
    Posted May 10, 2019 02:15 AM
    Thank's for your advice, I'II try asap and report.
    B.
  • 5.  RE: HPE 5940 and SFP+ problem
    Posted May 10, 2019 10:33 AM
    Rx       Tx         I downgraded my switches to R2612P01 and continue to have an UP  LR link over SMF.
    -14.61 -1.35   Your Rx power is non-existent.     Have you tried a simple port-to-port cabled loopback test?
    -2.44  -2.64  On my switch - with the JD094B link up.  Rx power is in the normal range.
    Does any 10G link come up with a port-to-port  loopback on your module ?
  • 6.  RE: HPE 5940 and SFP+ problem
    Posted May 10, 2019 04:09 AM
    These are the results of suggested commands:
    [HPE]display version
    HPE Comware Software, Version 7.1.070, Release 2612P01
    Copyright (c) 2010-2018 Hewlett Packard Enterprise Development LP
    HPE FF 5940 4-slot Switch uptime is 0 weeks, 1 day, 20 hours, 19 minutes
    Last reboot reason : User reboot
    Boot image: flash:/5940-cmw710-boot-r2612p01.bin
    Boot image version: 7.1.070, Release 2612P01
    Compiled Jul 31 2018 11:00:00
    System image: flash:/5940-cmw710-system-r2612p01.bin
    System image version: 7.1.070, Release 2612P01
    Slot 1:
    Uptime is 0 weeks,1 day,20 hours,19 minutes
    FF 5940 4-slot Switch with 2 Processor
    BOARD TYPE: FF 5940 4-slot Switch
    DRAM: 4096M bytes
    FLASH: 1024M bytes
    PCB 1 Version: VER.A
    PCB 2 Version: VER.A
    FPGA Version: NONE
    Bootrom Version: 234
    CPLD 1 Version: 003
    CPLD 2 Version: 002
    Release Version: HPE FF 5940 4-slot Switch-2612P01
    Patch Version: None
    Reboot Cause: UserReboot
    [SubSlot 0] Main Board
    [SubSlot 1] LSWM124XGT2Q
    [SubSlot 2] LSWM124XG2Q
    [HPE]
    [HPE]display transceiver alarm interface Ten-GigabitEthernet 1/2/24
    Ten-GigabitEthernet1/2/24 transceiver current alarm information:
    None
    [HPE]
    [HPE]display transceiver diagnosis interface Ten-GigabitEthernet 1/2/24
    Ten-GigabitEthernet1/2/24 transceiver diagnostic information:
    Current diagnostic parameters:
    Temp.(▒▒C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
    23 3.24 27.79 -14.61 -1.35
    Alarm thresholds:
    High 73 3.80 99.00 2.50 2.50
    Low -8 2.81 1.00 -16.40 -11.20
    [HPE]
    [HPE]display transceiver manuinfo interface Ten-GigabitEthernet 1/2/24
    Ten-GigabitEthernet1/2/24 transceiver manufacture information:
    Manu. Serial Number : CN8AJY30ZK
    Manufacturing Date : 2018-12-17
    Vendor Name : HPE
    [HPE]
    [HPE]display transceiver interface Ten-GigabitEthernet 1/2/24
    Ten-GigabitEthernet1/2/24 transceiver information:
    Connector Type : LC
    Vendor Name : HPE
    [HPE]
    It seems thet all is fine, but insn't...
    @bamaskas one thing: I've noticed my HPE Comware Software version is 7.1.070, Release 2612P01 while your release is R2612P02: is this the problem?
    Anyhow I'll upgrade the Comware ad report.
    Thank you all
    B.
    B.
  • 7.  RE: HPE 5940 and SFP+ problem
    Posted May 10, 2019 02:06 AM
    Thank's for reply,  I'll try to check the trancievers; for laser warning, don't worry, I know the laser dangerus effects: for a very quick test I use the camera on my smartphone, a selfielaser ;-)
