Comware
HPE 5940: HPE 10GBase-T SFP+ Transceiver
This thread has been viewed 54 times
  • 1.  HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 06, 2024 12:31 PM
    hello guys,
    I'm facing difficulties with my HPE 5940 switch. I'm trying to use some 10GBase-T SFP+ from HPE.
    My version is 7.1.070 with 6715 release.
    1GBase-T SFP+, works fine on my switch.
    However 10G transceivers won't let the same link go up. I see in logs: The transceiver is 10G_BASE_T_AN_SFP but the link stay down.
    I can't force link-type or speed manually of the interface, i get the error: operation failed. So it stays on auto.
    I see with the transeiver info the connector type is RJ45 but nothing really different with the 1G transceivers.
    Have you ever face this probleme?
    Regards
  • 2.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 07, 2024 03:48 AM
    Hi
    There is no 10G Base-T SFP+ in the supported accessories list for 5940 switches. What is the exact model ref ? JH395A ? JH390A ? other ?
    Which port are you trying to use ? What is on the other side ?
    Frederic
    (kudos welcome)
  • 3.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 08, 2024 03:30 AM
    The exact model of the 10 Base-T SFP+ is HP 813874-B21.
    The exact model of the switch is JH390A.
    Regards
  • 4.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 08, 2024 04:00 AM
    Frederic
    (kudos welcome)
  • 5.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 08, 2024 04:08 AM
    I tried to use it on another JH390A. But it doesn't work.
    I also tried with a palo-alto PA-820. The result is the same.
    So both port are in 10G.
    I tried on a PC (with a 1G port). It didn't work either.
    Btw I was using a RJ45 cat 6A.
    But if you say in your first answer that "10G Base-T SFP+ in the supported accessories list for 5940 switches". I won't be able to use it anyway?
  • 6.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 08, 2024 05:05 AM
    hi
    Try to loop on the same switch : for example, 1 sfp+ in port Te1/0/1 and another one in Ten1/0/2, put a RJ45 cable between them and see what happens.
    Is there any entry in the log ?
    Please post the result of
    display interface te1/0/1
    display interface te1/0/2
    display transceiver interface
    (adapt the port numbers to your context)
    Comware platform is very "permissive" so you should be able to use these SFP+
    Frederic
    (kudos welcome)
  • 7.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 09, 2024 10:40 AM
    Hi, I don't know how I didn't that in logs but indeed there is this alarm:
    I googled it and that means that there is an issue detected locally (bad data/signal).
    A remote fault is raised by a port that is receiving a remote fault frame from the far end (port with local fault).
    But is there a way to solve this problem and "allow" this sfp+ ?
    LOGS:
    %Jan  1 00:26:57:692 2011 switch IFNET/4/IF_LOCAL_FAULT_RESUME: A local fault alarm recovers on Ten-GigabitEthernet1/0/20.
    %Jan  1 00:26:57:684 2011 switch IFNET/4/IF_LOCAL_FAULT_RESUME: A local fault alarm recovers on Ten-GigabitEthernet1/0/19.
    %Jan  1 00:26:39:286 2011 switch OPTMOD/4/MODULE_IN: Ten-GigabitEthernet1/0/19: The transceiver is 10G_BASE_T_AN_SFP.
    %Jan  1 00:26:22:790 2011 switch OPTMOD/4/MODULE_IN: Ten-GigabitEthernet1/0/20: The transceiver is 10G_BASE_T_AN_SFP.
    display interface Ten-GigabitEthernet
    1/0/19
    Current state: DOWN
    Line protocol state: DOWN
    IP packet frame type: Ethernet II, hardware address: 943f-c2dd-27a7
    Description: Ten-GigabitEthernet1/0/19 Interface
    Bandwidth: 10000000 kbps
    Loopback is not set
    Media type is stack wire, port is 10G_BASE_T_AN_SFP
    Unknown-speed mode, unknown-duplex mode
    Link speed type is autonegotiation, link duplex type is autonegotiation
    Flow-control is not enabled
    Maximum frame length: 10000
    Allow jumbo frames to pass
    Broadcast max-ratio: 100%
    Multicast max-ratio: 100%
    Unicast max-ratio: 100%
    Known-unicast max-ratio: 100%
    PVID: 1
    MDI type: Automdix
    Port link-type: Access
     Tagged VLANs:   None
     Untagged VLANs: 1
    Port priority: 0
    Last link flapping: Never
    Last clearing of counters: Never
    Current system time:2011-01-01 00:29:48
    Last time when physical state changed to up:-
    Last time when physical state changed to down:2011-01-01 00:01:36
     Peak input rate: 0 bytes/sec, at 2011-01-01 00:02:27
     Peak output rate: 0 bytes/sec, at 2011-01-01 00:02:27
     Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
     Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
     Input (total):  0 packets, 0 bytes
             0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses
     Input (normal):  0 packets, - bytes
     Input:  0 input errors, 0 runts, 0 giants, 0 throttles
             0 CRC, 0 frame, - overruns, 0 aborts
             - ignored, - parity errors
     Output (total): 0 packets, 0 bytes
     Output (normal): 0 packets, - bytes
     Output: 0 output errors, - underruns, - buffer failures
             0 aborts, 0 deferred, 0 collisions, 0 late collisions
             0 lost carrier, - no carrier
    Ten-GigabitEthernet1/0/19 transceiver information:
      Transceiver Type              : 10G_BASE_T_AN_SFP
      Connector Type                : RJ45
      Wavelength(nm)                : N/A
      Transfer Distance(m)          : 30(TP)
      Digital Diagnostic Monitoring : NO
      Vendor Name                   : Methode Elec.
    1/0/20
    Current state: DOWN
    IP packet frame type: Ethernet II, hardware address: 943f-c2dd-27a8
    Description: Ten-GigabitEthernet1/0/20 Interface
    Loopback is not set
    PVID: 1
    MDI type: Automdix
     Tagged VLANs:   None
     Untagged VLANs: 1
    Port priority: 0
    Current system time:2011-01-01 00:30:39
    Ten-GigabitEthernet1/0/20 transceiver information:
  • 8.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 13, 2024 04:15 AM
    I shall propose to check the cable quality/length
    If possible, can you change the cables for new ones ?
    Did you try to "loop back" one port to another on the same switch (with a short RJ45 patch cord) ?
    Frederic
    (kudos welcome)
  • 9.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 13, 2024 11:03 AM
    please check the cable. You need at least a Cat6 (250mhz) for up to 55m. Better would be a Cat6A (500mhz) or higher with shielding.
  • 10.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 22, 2024 10:50 AM
    Hi Biid00x,
    I'm faced with the same problem.
    The same switch and the same transceiver.
    Please set the command port up-mode at the port level and after it will be work. But as you understand there is problem that port will be UP forever.
  • 11.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 23, 2024 05:04 AM
    Hello,  indeed it works, thanks!
    But it's not the best. Is HPE aware of this "bug"? If not, how can we report this?
    Regards
  • 12.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 23, 2024 06:45 AM
    You can open the TAC case for this to report it to HPE (best option). Or you can use Inovation zone (if you are a partner or over the partner) to open an enhancement request.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 13.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 23, 2024 07:33 AM
    Hi sir,
    I can't contact the seller anymore, how can I get the firmware without contacting the seller? Is it possible to re-upload the firmware? Please help me to re-upload this firmware. Because my device has not been working for a month.
    febian.
  • 14.  RE: HPE 5940: HPE 10GBase-T SFP+ Transceiver
    Posted Aug 23, 2024 08:52 AM
    Edited by GorazdKikelj Aug 24, 2024 01:49 AM
    Try to contact TAC support with SN of the switch. If it still has a valid warranty you should be able to get the FW.
    For you to download the FW you need to finish onboarding process for your HPE passport to networking support portal.
    Gorazd Kikelj
    MVP Guru 2024
