Network Management
HPE 5945 slot 2 configure default gateway
  • 1.  HPE 5945 slot 2 configure default gateway
    Posted Jul 19, 2022 06:08 PM
    i am new to hpe systems. I have this model 5945 on which I have to set the default gateway for a vlan l3, which I will use for management. The rest will be used at level 2. I have seen on other models that it gives you the possibility to enter the command ip default-gateway, but on this one not. Do you know if there are ways to do it?
