Wired Intelligent Edge
HPE Aruba 3810 and 2930 SFP+ trunking...
  • 1.  HPE Aruba 3810 and 2930 SFP+ trunking...
    Posted Nov 27, 2018 08:04 AM
    We have the following switches:
    1x Aruba 3810M-16P (JL075A)
    1x Aruba 3810M-48P (JL072A)
    4x Aruba 2930F (JL254A)
    The JL075A and JL072A have a separate SFP + module (JL083A) 4x10 Gpbs
    I would like to connect the switches via SFP + together.
    The JL075A to JL072A via the SFP + module
    The JL254A on the JL075A via the SFP + port
    I want to use at least two ports per switch to realize the uplink.
    All servers are connected to the Fiber Switch JL075A via AOC cables
    The JL072A works as a core switch
    We have 6 vlans. It is intended that these can co-exist with each other except the guests subnet VLAN30
    My question is:
    Should i use port trunking or LACP?
    For example:
    trunk 45-46 LACP?
    or
    trunk 45-46 trunk?
    Or better advice so that I can make maximum use of the bandwidth.
    Thanks.
    Rene
    #trunking
    #LACP
    #sfp+
  • 2.  RE: HPE Aruba 3810 and 2930 SFP+ trunking...
    Posted Nov 27, 2018 11:36 AM
    Yes, you should. LACP Trunks help your uplinks to gain in resiliency and traffic (re)distribution.
    The correct syntax is trunk 45-46 trk1 lacp, that way interface 45 and 46 will be physical member interfaces of LAG (Link Aggregation Group) named trk1 using LACP.
  • 3.  RE: HPE Aruba 3810 and 2930 SFP+ trunking...
    Posted Nov 28, 2018 05:17 AM
