Dear all,
we have two datacenter with two 5400R zl2 in each datacenter as core, as we need a configuration with no SPOF.
With our current setup, we had connection errors. It looks like our setup ist not working as expected and the switches in each datacenter receive mac addresses within the same vlan from two uplinks.
I will attach two pictures. One with our current setup and a second one with "the only right solution?"
Who can tell if our setup should work or if it just works another way?
VSF is no option, because we have only v2 modules.
I think there is a solution, because HPE documents Distributed trunking overview shows a diagram, but no configuration example.
