Hello! I run two HPE FF 5700-32XGT-8XG-2QSFP+ in IRF, they are run quite old software Release 2432P05. Today , without any visible changes in environment, we got problem in routing, which, as we found is in this switches ospf.
Now we have, for instance, down interface:
display interface Vlan-interface 30
Vlan-interface30 Current state:
Administratively DOWN
Line protocol state: DOWN
But it is in routing table:
display ip routing-table | inc Vlan30
192.168.100.0/28 OSPF 10 12 192.168.200.89 Vlan30
192.168.107.0/24 OSPF 10 5 192.168.200.89 Vlan30
192.168.108.0/24 OSPF 10 6 192.168.200.89 Vlan30
and so on
Also I can't do any configuration changes in ospf, or display any info- it just hangs.
What is worse- I can't reset ospf process:
reset ospf process
Reset OSPF process? [Y/N]:y
It hangs forever.
Questions: 1. Can I restart ospf process without rebooting all switches in IRF? 2. Is this known problem and I need just upgrade firmware?
Thank you!
