Wired Intelligent Edge
HPE FlexFabric 5700 enhanced irf replacement
This thread has been viewed 26 times
  • 1.  HPE FlexFabric 5700 enhanced irf replacement
    Posted Nov 03, 2021 02:58 AM
    Hi Guys,
    As you know HPE FlexFabric 5700 is EoS and HPE released 5710 instead, I need to know if its also supporting enhanced irf with 5900/12900 as a parent switch?
    if no, what is the replacement technology to do the same?
    Mahmoud Nagah
  • 2.  RE: HPE FlexFabric 5700 enhanced irf replacement
    Posted Nov 03, 2021 03:19 AM
    Edited by mnagah Nov 07, 2021 03:00 AM
    Enhanced IRF (so called 'IRF 3') has been deprecated in 5700 series as well. You are pretty much locked to version 2418 if you still use it as more recent versions silently drop the feature.
    HPE decided to go with IRF 3.1 wich in contrast to the IRF 3 is standard-based (I think it's based on IEEE 802.1BR). 5710 support IRF 3.1
    More details can be found here - https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00078536en_us
