Comware
HPE FlexNetwork 10508 Switch Chassis
  • 1.  HPE FlexNetwork 10508 Switch Chassis
    Posted Jul 30, 2021 03:10 PM
    Dear, I am new here and would like your help with a question based on your experiences.
    I have an HPE FlexNetwork 10508 switch chassis and I need to shut it down, that is, shut it down, not reboot it.
    Do I have to follow any procedure for an orderly shutdown or just turn it off and disconnect the electrical connection?
    And if I have to take into account something else.
    Thanks a lot
    #Switching
  • 2.  RE: HPE FlexNetwork 10508 Switch Chassis
    Posted Jul 30, 2021 03:48 PM
    Hello @ Licha,
    There are no particular procedure.
    You can save the configuration and just turn it off and disconnect the electrical connection.
    Thanks!
