Network Management
HPE IMC network topology export and import
  • 1.  HPE IMC network topology export and import
    Posted Mar 27, 2019 04:08 AM
    we have replaced the existing HPE IMC server with a new server.
    The database import failed.
    Is there a way to export the network topology from the previous HPE IMC and import it to the new server?
    Thank you and best regards
  • 2.  RE: HPE IMC network topology export and import
    Posted Apr 02, 2019 06:49 AM
    The only way to import the network topology is to restore the database backup from the old IMC to new IMC server.
    What is the error you see when you try to restore the database. If requried log a support case to fix your database restoraton issue.
