Comware
  • 1.  HPE MSR954 router JH373A
    Posted May 10, 2018 03:44 AM
    Добрый день.
    Прошу помощи в настройке роутера HPE MSR954 router JH373A. Настройки все сделал, вставил сим карту, интернет поднялся, из консоли пингую 8.8.8.8, но как раздать на порты интернет? Контроллер Cellular 2/0 настроен, но он не присвается на ip route-static. А интренефейса Cellular нет. Подскажите что необходимо сделать.
    Спасибо!
    Good afternoon.
    Please help in configuring the router HP router MSR954 JH373A. Settings all done, insert the SIM card, the Internet rose up from the console pinguy 8.8.8.8, but how to distribute the desks on the Internet? The Cellular 2/0 controller is configured, but it is not assigned to IP route-static. There is no Cellular interface. Tell me what to do.
    Thank you!
  • 2.  RE: HPE MSR954 router JH373A
    Posted May 10, 2018 04:29 AM
    <HPE>disp cur
    version 7.1.064, Release 0605P20
    sysname HPE
    clock timezone Moscow add 03:00:00
    clock protocol none
    dialer-group 1 rule ip permit
    dialer-group 57 rule ip permit
    dhcp enable
    dhcp server always-broadcast
    dns proxy enable
    dns domain
    dns server
    dns server
    password-recovery enable
    vlan 1
    vlan 16
    vlan 251
    dhcp server ip-pool lan1
    gateway-list 10.26.***.**
    network 10.26.***.** mask 255.255.255.224
    address range 10.26.***.** 10.26.***.62
    dns-list 8.8.8.8
    dhcp server ip-pool vlan16
    network 10.26.***.0 mask 255.255.255.224
    dns-list 8.8.8.8 10.98.**.10 10.98.**.11
    apn-profile profile137
    apn static internet.beeline.ru
    authentication-mode pap-chap user beeline password cipher $c$3$5bPmzODLGMDD8riRQR+rS+Qr5twl4g4Zwh8=
    controller Cellular0/0
    controller Cellular1/0
    eth-channel 0
    controller Cellular2/0
    description Single_Line1-OTHER
    eth-channel 0
    interface Aux0
    interface Serial0/0
    interface Virtual-Template0
    interface NULL0
    interface Vlan-interface1
    tcp mss 1280
    interface Vlan-interface16
    ip address 10.26.***.** 255.255.255.224
    dhcp server apply ip-pool vlan16
    interface Vlan-interface251
    ip address 10.26.***.9 255.255.255.248
    interface GigabitEthernet0/0
    port link-mode route
    ip address 10.26.***.1 255.255.255.248
    interface GigabitEthernet0/1
    port link-mode bridge
    port access vlan 251
    interface GigabitEthernet0/2
    port access vlan 16
    ip address dhcp-alloc
    interface GigabitEthernet0/3
    port access vlan 16
    interface GigabitEthernet0/4
    port access vlan 16
    interface Eth-channel1/0:0
    dialer circular enable
    dialer-group 57
    dialer timer autodial 5
    dialer number *99# autodial
    ip address cellular-alloc
    tcp mss 1024
    apn-profile apply profile137
    interface Eth-channel2/0:0
    dialer-group 1
    tcp mss 1024
    security-zone name Local
    security-zone name Trust
    security-zone name DMZ
    security-zone name Untrust
    security-zone name Management
    scheduler logfile size 16
    line class aux
    user-role network-admin
    line class tty
    user-role network-operator
    line class vty
    line aux 0
    line vty 0 63
    authentication-mode scheme
    ip route-static fast-reroute auto
    ip route-static 0.0.0.0 0 Eth-channel2/0:0
    domain system
    domain default enable system
    role name level-0
    description Predefined level-0 role
    role name level-1
    description Predefined level-1 role
    role name level-2
    description Predefined level-2 role
    role name level-3
    description Predefined level-3 role
    role name level-4
    description Predefined level-4 role
    role name level-5
    description Predefined level-5 role
    role name level-6
    description Predefined level-6 role
    role name level-7
    description Predefined level-7 role
    role name level-8
    description Predefined level-8 role
    role name level-9
    description Predefined level-9 role
    role name level-10
    description Predefined level-10 role
    role name level-11
    description Predefined level-11 role
    role name level-12
    description Predefined level-12 role
    role name level-13
    description Predefined level-13 role
    role name level-14
    description Predefined level-14 role
    user-group system
  • 3.  RE: HPE MSR954 router JH373A
    Posted May 10, 2018 08:40 PM
    On the router:
    display ip interface brief
    display ip rout
    On the host that is trying to access the internet:
    ipconfig /all
