It will retain the original config. Let me explain its logic in details:
1. reboot, Ctrl+D, option 4, Ctrl+B
2. Option 7 - Skip Current System Configuration
3. Option 0 - Reboot
We set the Bootrom to ignore the "saved-configuraiton" file on the next reboot and load an empty configuration.
4. Unlock CLI (special unlock password should be used. This is an exception process. Never give out the password to the customer, rather assist him on remote session and put the password by yourself)
5. Enter following commands:
system-view
configuration replace file startup.cfg
This command loads the "startup.cfg" (default location of the "saved-configuration") and applies it. This is the tricky part - the old password (the forgottern one) is getting applies too, BUT we are already logged in, so it won't ask us for this password until we log out
#Current configuration will be lost, save current configuration? [Y/N]: N
local-user admin
undo password
This command will delete the current password and will set a default one. This is specific of this platform (1950), on other Comware platforms you would normally set another password here by "password simple <your_new_password>" command, but in 1950 you can just delete the password and it will become default.
return
save safely force
! Here we save our new "current-configuration" without password under the context of user 'admin' to the "saved-configuration" file.
reboot
! When the device reboots, it will load the confif without password and the Web GUI will be accessible with default credentials. All other settings should retain untouched. I recommend you to change the password from the GUI as soon as you log in to the switch.
