Wired Intelligent Edge
  • 1.  HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Jan 05, 2020 10:32 PM
    Hi, is there any datasheet or installation guide for HPE QSFP/SFP+ Adaptor Kit (655874-B21)? I want to check the compatible SFP+ transceiver for this HPE QSFP/SFP+ Adaptor Kit?
    Thank you!
  • 2.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Jan 06, 2020 03:57 AM
    Looks to me like a server product. On this forum you will most likely see people with networking knowledge. This looks to be the product brief for that adaptor, which appears to be a joint product for HPE.
  • 3.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Jan 06, 2020 04:55 PM
    This is a passive adaptor and I used it in the past with different SFP+ transceivers without any problem. However, you'd better to qualify the adaptor/transceiver pair with some testing before proceeding with large quantity.
  • 4.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Feb 24, 2020 02:11 PM
    In what Aruba switches have you or anyone else test? I have one Aruba 8320 and want to use one port with sfp+
  • 5.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Feb 24, 2020 06:47 PM
    IMHO Aruba 8320 Switch series doesn't support any QSFP+ to SFP+ splitting cable...no breakthrough (no 40Gbps into 4x10Gbps interfaces).
  • 6.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Sep 21, 2021 12:14 PM
    Any chance the Aruba 8320 supports the 655874-B21 now with the allow unsupported transceiver command?
    Eugene Grutman
  • 7.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Sep 21, 2021 07:56 PM
    Hi Eugene, during last 19 months things have changed...and the Aruba 8320 (40G model like the JL579A) currently supports QSFP+ DAC/Fiber Breakout cables (QSFP+ to 4xSFP+) with these SKUs:
    • DAC Breakout 721064-B21
    • AOC Breakout 721076-B21 (where AOC= Active Optical Cable)
    With latest ArubaOS-CX 10.07 and 10.08 software builds theoretically the above breakout cables should be properly recognized by the switch.
    AFAIK the 655874-B21 (an HPE QSFP+ to SFP+ adapter) is not supported.
    Davide Poletto
  • 8.  RE: HPE QSFP/SFP+ Adaptor Kit Compatible SFP+ Transceiver
    Posted Sep 13, 2023 12:10 PM
    This thread started in 2020, and as Davide Poletto had said " things have changed".
    The 655874-B21 (yes, an HPE Server division product, not an HPE Aruba part) is indeed supported in select switches and ports.
    As documented in the AOS-S and AOS-CX Transceiver Guide, (Edition 13, page 46-47)
    Page 47 lists the switches where this is supported.
    This is a QSA28, meaning it's supported in QSFP28(100G) ports and QSFP+(40G).  Please take note of the highlighted paragraph I've noted in the screen grab.
    Also, the link I provided assumes you have a Login to the ASP (Aruba Support Portal) -- as of Aug 18, 2023 a registered account and login is required to download documentation and software.
    Ed Kurata, Aruba Sr. Product Line Manager,
    Switching , Transceivers, Accessories, Power, and other things
    Roseville CA, USA
