Wired Intelligent Edge
  • 1.  HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jun 27, 2016 07:56 AM
    Anyone know if it is possible to use 1GB SFP moduls in a 10GB SFP+ slot?
    I have a 5406zl with SFP+-module J9538A. It works well with 10GB modules and DA-cables.
    Recently I purchased a HP J4859C 1GB SFP-module (HPE X121) but I get an error when inserting it into the SFP+ module.
    Is this supposed to work? I know our Ciscos readily eat 1GB modules in 10GB slots.
    Transceiver Technical Information:
    Port # | Type | Prod # | Serial # | Part #
    C4 | ?? | | |
    The following transceivers have extra information:
    Port # Message
    Port C4 Self test failure.
  • 2.  RE: HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jun 27, 2016 11:48 AM
    Check that active System Image is at least K.15.02.0004 or newer (this is a requirement to grant the usage of J4859C into the J9358A 8 Ports 10 GbE SFP+ v2 zl Module): see here for details (Sheet 5).
    Are you sure that your J4859C is really genuine?
    Another source of information is this one: there is clearly stated that a "J4858C HP X121 1G SFP LC SX Transceiver connects fine when put in a HP 8-port 10-GbE SFP+ v2 zl Module (J9538A) in a 5406zl switch." instead it runs into an issue when it is moved into a J9993A v3 zl2 Module of an HPE 5400R zl2 chassis, indeed is reported that the same "J4858C HP X121 1G SFP LC SX Transceiver won't Connect when inserted in a HP J9993A 8p 1G/10GbE SFP+ v3 zl2 Module in a 5400R zl2 Switch.".
  • 3.  RE: HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jun 28, 2016 04:38 AM
    Thanks parnassus.
    We use firmware 15.04.0003 so it should work.
    The SFP module is a cheap knock-off, it is what I got when ordering from our procurement department. It is supposed to be J4859C-compatible. Guess it just plain isn't. Will try to get genuine, at least I now know they should work.
  • 4.  RE: HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jun 28, 2016 06:05 AM
    Yep I'm quite sure that being only J4859C compatible, from the PoW of HPE, it's definitely not enough: it's required a true genuine HPE part which, judging from the HP suggested price advertised here, looks not-so-cheap.
  • 5.  RE: HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jul 11, 2016 09:38 AM
    For the record:
    Got original J4859C and they work fine in the SFP+ modules.
  • 6.  RE: HPE X121 1GB SFP module in 10GB SFP+ slot? ProCurve 5406zl
    Posted Jul 11, 2016 10:06 AM
    That's great!
