  • 1.  IAP 103 MAX
    Posted Oct 09, 2017 03:39 PM
    Hi All,
    I am reconfiguring my network so that all IAPs are managed from single web intereface (only virtual controller), using either dynamic vlan or vlan pool
    My question is how many 103 i can connect in the same network and what are the disadvantages.
  • 2.  RE: IAP 103 MAX
    Posted Oct 10, 2017 04:20 AM
    The Instant cluster limit is 100 APs, but the IAP-103 is not high end so it may not be suitable to be the Virtual controller in such a large network..  How many did you have to deploy?
  • 3.  RE: IAP 103 MAX
    Posted Oct 11, 2017 09:24 AM
    Thank you for your response.
    I have 30 103 IAP
    and can get in the future 35 or 40
  • 4.  RE: IAP 103 MAX
    Posted Oct 11, 2017 11:48 AM
    If you design properly, I would expect 35 IAP-103's in a cluster to work.
    Check out the Aruba Instant Validated Reference Design guide for more information.
