  • 1.  IAP-103 to manage IAP-93 possible ?
    Posted Aug 06, 2014 03:04 AM
    hy all,
    we are looking at replacing our IAP-93 to brand new IAP-103.
    instead of replacing them all, we would do it step by step.
    So i was wondering if i can deploy an IAP-103 et manage all others IAP-93 that i already have ?
    Thanks a lot for your advices :)
    Cheers!
    Xinity
  • 2.  RE: IAP-103 to manage IAP-93 possible ?
    Posted Aug 06, 2014 03:13 AM
    yes you can.  Just ensure the 103 is on the same firmware version as the 93 before you plug them into the network
  • 3.  RE: IAP-103 to manage IAP-93 possible ?
    Posted Aug 06, 2014 03:19 AM
    fast answer !!
    Thanks a lot !
    do you mean that if i wan't to manage my IAP-93 i should not update my IAP-103 to a firmware not available to the IAP-93 ?
    regards,
    Xinity
  • 4.  RE: IAP-103 to manage IAP-93 possible ?
    Posted Aug 06, 2014 03:21 AM
    correct, they all need to be on the same firmware.  You should only update to a firmware that is available for the 93 also, if you want to manage them in the same cluster.
  • 5.  RE: IAP-103 to manage IAP-93 possible ?
    Posted Aug 06, 2014 04:57 AM
    At this moment, the only firmware that supports both IAP-103 and IAP-93 is version 4.1.0.1 (6.4.0.3-4.1.0.1_45063).
    Make sure that you have both the IAP-103's and the IAP-93's on that version or newer. You will need to use the manual upgrade procedure (download from support website, and upload to the IAP under maintenance-firmware) as this version is not yet available in the cloud.
