Ok, if you need help setting up the captive portal on the VC, please let us know.
Daniel Ruiz
If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
Original Message:
Sent: Nov 06, 2024 02:40 PM
Subject: IAP 103 - VIRtual Controller - Captive Portal
never mind... found it..
Original Message:
Sent: May 22, 2019 12:25 AM
You can certainly do it with an IAP only. You have an option to use IAP internal captive portal or use an external captive portal like ClearPass.
