  • 1.  IAP-103 will not join cluster
    Posted Oct 01, 2014 02:49 PM
    Very odd situation here.
    IAP-103 deployment of 23 APs, firmware of the VC 4.1.0.1, all of other APs factory defaulted and running 4.1.0.0 (shipped firmware).
    Network installed, VC connected and up, then remaining 22 APs connected,
    Total of 22 APs show up on the VC but not the last AP.
    Running "show log system"
    shows the following
     10/1/2014 12:56:40 PM    Target: 9c:1c:12:cc:af:a8    Command: show log system
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.23, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.28, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.17, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.25, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.37, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.33, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.27, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.31, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.20, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.35, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.29, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.19, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.36, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.30, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.32, using url 0, auto save disable 0.
    Oct  1 11:51:47  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Isc_send_request
    Oct  1 11:51:50  cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  APAS provision failed, code: fail-prov-no-shipped
    Oct  1 11:52:02  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Activate failed, enabling factory SSID
    Oct  1 11:52:08  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.18, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.26, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.15, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.22, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.34, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.21, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.23, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.28, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.25, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.17, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.33, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.37, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.27, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.31, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.20, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.35, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.29, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.36, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:12  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.19, slave 8438 vs master 60442, error_cnt 1, recover_sent 0.
    Oct  1 11:52:50  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Isc_send_request
    Oct  1 11:52:54  cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  APAS provision failed, code: fail-prov-no-shipped
    Oct  1 11:53:06  cli[1721]: <341108> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  sess_validate_sid: 179 invalid session client-38.108.87.99 sid-ba0dbb1d97e6c52ef3602e5f376e.
    Oct  1 11:54:53  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Isc_send_request
    Oct  1 11:54:56  cli[1721]: <341005> <ERRS> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  APAS provision failed, code: fail-prov-no-shipped
    Oct  1 11:54:57  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ae:40, version-6.4.0.2-4.1.0.0_44004, ccode_idx-255.
    Oct  1 11:55:01  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Image_sync_via_master_file
    Oct  1 11:55:01  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_image_mismatch url (ap classPegasus) to 192.168.10.24
    Oct  1 16:56:08  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.36, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:11  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.18, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.15, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.22, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.34, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.21, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.28, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.23, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.25, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.27, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.37, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.31, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.20, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.35, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.17, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.29, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:15  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.33, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:16  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.19, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:16  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.30, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
    Oct  1 16:56:16  cli[1721]: <341132> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Check sum error for AP-192.168.10.32, slave 60442 vs master 64600, error_cnt 1, recover_sent 0.
     10/1/2014 12:55:55 PM    Target: 9c:1c:12:cc:af:a8    Command: show log system
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ad:66, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.27.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:e3:54, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.31.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ae:f8, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.35.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ae:38, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.20.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:77:1a, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.29.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:b0:90, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.19.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ad:68, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.36.
    Oct  1 11:51:14  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ae:ea, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:14  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.30.
    Oct  1 11:51:15  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:b0:4c, version-6.4.2.0-4.1.1.0_46028, ccode_idx-255.
    Oct  1 11:51:15  cli[1721]: <341165> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send image match to 192.168.10.32.
    Oct  1 11:51:16  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.18, using url 0, auto save disable 0.
    Oct  1 11:51:16  cli[1721]: <341097> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  recv_image_check: mac-9c:1c:12:cc:ae:40, version-6.4.0.2-4.1.0.0_44004, ccode_idx-255.
    Oct  1 11:51:21  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  Image_sync_via_master_file
    Oct  1 11:51:21  cli[1721]: <341004> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_image_mismatch url (ap classPegasus) to 192.168.10.24
    Oct  1 11:51:21  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.15, using url 0, auto save disable 0.
    Oct  1 11:51:21  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.26, using url 0, auto save disable 0.
    Oct  1 11:51:21  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.34, using url 0, auto save disable 0.
    Oct  1 11:51:21  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.22, using url 0, auto save disable 0.
    Oct  1 11:51:22  cli[1721]: <341199> <WARN> |AP 9c:1c:12:cc:af:a8@192.168.10.16 cli|  send_config_init: send config to slave 192.168.10.21, using url 0, auto save disable 0.
    ent 0.
    Noticing that the AP couldn't get its firmware from the VC, I downgraded the cluster to 4.1.0.0, voila, all 23 APs are online.
    Then upgraded it to 4.1.0.1 and 4.1.1.0 and the same situation happens with the same AP, only 22 appear not the 23rd.
    Had to downgrade to 4.1.0.0 in order to deploy the network.
    Any idea what could be causing this? faulty AP possibly? But it works on the shipped firmware.
  • 2.  RE: IAP-103 will not join cluster
    Posted Oct 02, 2014 01:32 AM
    You could try taking that AP, connecting to instant, upgrade it, and then join it back to the cluster.
  • 3.  RE: IAP-103 will not join cluster
    Posted Oct 08, 2014 09:55 AM
    Tried that, didn't work, what happened was that it was the only one online and the others couldn't join.
