IAP-105 and AP175 on VLANs Tagged or untagged ports??
  • 1.  IAP-105 and AP175 on VLANs Tagged or untagged ports??
    Posted Mar 20, 2014 03:47 PM
    Hi Guys,
    I have an issue where if the aruba access points are on a Tagged port they do not see each other and autoconfigure, but if I change the port to untagged, they auto configure and see each other, the issue then is the client does not get a DHCP address on the SSID associted with that VLAN.
    Any ideas? Switch is Netgear Pro Safe M4100-50G-POE (GSM7252P)
    Rob.
  • 2.  RE: IAP-105 and AP175 on VLANs Tagged or untagged ports??
    Posted Mar 20, 2014 07:51 PM
    OK solved this, Untagged the primary VLAN and then set the SSID that uses it to netwok assiged and default, instead of static VLAN!
