Become a Member
Can I add 9 IAP 305's to an existing 7 IAP 105 CLuster? Thanks.
Unfortunately you cannot, because support for IAP-105s was ended with 4.3.0.0:
http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Command/Core_Download/Default.aspx?EntryId=24557
The minimum version of software for the IAP-305 is 4.3.1.0
http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
You could add a controller and convert the IAP-105s to AP-105.
AP-105 is still supported on the most recent AOS version, so it can coexist with AP-305 in a controller-based deployment..
Thanks for the info guys, I really appreciate your help, I'd love to get a controller etc but money is a too tight, would IAP 205's be compatible?
Yes, 205s are compatible.
Min versions for 205 is 4.1.1.0
Last supported version for 105 is 4.2
Just be aware that end-of-sale of the IAP-205 has been annouced (effective 5/1/2018).
