  • 1.  IAP 105 keep on rebooting
    Posted Nov 23, 2013 10:34 PM
    Hi All,
    Have anyne come across this issue? i have 5 ap 105 and all keep on reebooting with error(screenshot). DHCP is enable on the network.Level 49.png
  • 2.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:17 PM
    Please read this bulletin
    this could be your issue
    Cheers
    Carlos
    Attachment(s)
  • 3.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:23 PM
    Hi Carlos,
    I wil check the S/N and the details..
    thanks
  • 4.  RE: IAP 105 keep on rebooting
    If that is not your issue,  What i mean is that your ap does not belong to those Serial numbers.  Then your AP must be flaulty and you might need to open a support case to make them change the ap to you.
    Cheers
    Carlos
  • 5.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:27 PM
    Hi Carlos,
    Based on your experience, If that is not the issue(my AP not belong to those S/N), the error indicate the the AP is faulty?
  • 6.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:33 PM
    When you got crazy errros like this all you can do is
    clear os
    reboot and if it keep happening which i guess it will, you will need to open a support case and tell them that you already did clear os becasue they always tells you to do
    factory default
    clear os
    If that doesnt work and you keep getting those errors they will RMA your APS, as there is nothing else you can actually do besides that.
    To not loose time tell the tac
    if you already did it
    I already did clear OS, i also read the field bulletin AP-100-TMP and i verified that the serials does not belong to that range... and ask them to please to RMA your AP.
    They will just asnwer you to give them your address etc etc.
    Cheers
    Carlos
  • 7.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:35 PM
    Hi Carlos,
    Noted with thanks
  • 8.  RE: IAP 105 keep on rebooting
    Posted Nov 23, 2013 11:36 PM
    Dont worry we are all here to help :)
    Cheers
    Carlos
