IAP-105 Not joining cluster
  • 1.  IAP-105 Not joining cluster
    Posted Nov 21, 2016 11:49 PM
    So I've done a bunch of reading and looked at several posts. I cannot find an answer to my issue.
    I have two IAP-105-JP. One has been set up with a main SSD and a guest SSD. It has a static IP, auto join is on, it is set to preferred master, plugged into the same switch which has only one VLAN. They have the same firmware.
    The other one has a static IP, auto join is on, and it is plugged into the same switch. On the advanced system page, I did not put in the IP of the Virtual Controller.
    I have looked at the logs and really do not see anything that jumps out at me.
    So what do I need to do to the unconfigure IAP-105-JP to have it join with the configured one.
    Thank you in advance
  • 2.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 06:30 AM
    You should try making the second AP DHCP if possible.
  • 3.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 12:59 PM
    Set it to DHCP. Rebooted IAP.
    How long does it take to auto join?
    Been about 30 minutes.
  • 4.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 01:22 PM
    Can you ping the AP?  SSH into the AP when you can ping it and type "show log system" to see what is happening to it....
  • 5.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 01:45 PM
    Yes. I was able to SSH and ran the attached log.
    Attachment(s)
    txt
    Log.txt   48 KB 1 version
  • 6.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 05:53 PM
  • 7.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 11:30 PM
    So I did a reset and still not joining. I changed the admin password to match the master.
    I left everyhting else alone.
    Log attached
    Attachment(s)
    txt
    log.txt   6 KB 1 version
  • 8.  RE: IAP-105 Not joining cluster
    Posted Nov 22, 2016 11:51 PM
  • 9.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 09:58 AM
    Yes, auto join is on.
  • 10.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 10:47 AM
    Are they are on the same subnet?  It seems like that AP does not "see" any other APS.
  • 11.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 10:50 AM
    Yes it is the same subnet. They are both plugged into the same Dell POE switch. There are no VLANs.
  • 12.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 10:53 AM
    The only thing that I can think of is that you have the subnet mask configured wrong on the first AP, so it cannot see the second one.  I would try making them both DHCP...
  • 13.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 01:46 PM
    So I set the mainAP to DHCP, rebooted it. Once it came up I rebooted the slaveAP. Still not joining.
    Logs are attached.
    Attachment(s)
    txt
    SlaveAP.txt   25 KB 1 version
    txt
    MainAP.txt   4 KB 1 version
  • 14.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 01:49 PM
    I would ping one AP from another to see if they can reach each other.
  • 15.  RE: IAP-105 Not joining cluster
    Posted Nov 23, 2016 02:29 PM
    I was able to SSH into them both and ping the other one with no issues
  • 16.  RE: IAP-105 Not joining cluster
    Posted Nov 25, 2016 02:00 PM
    So today I reset both IAPs not just the one I am tring to get joined.
    They both came back up joined. Not sure what was going on with the main one but I guess it wasn't allowing the other one to join.
    I reset up the SSIDs, password, and guest network.
    They are workign great together.
    Thank you for all your help.
