  • 1.  IAP-115 and IAP-225 In One Cluster
    Posted May 03, 2016 11:06 PM
    I would like to ask whether IAP-115 and IAP-225 can work in one cluster?I try to set these 2 AP but the IAP-115 was not join into the cluster.
  • 2.  RE: IAP-115 and IAP-225 In One Cluster
    Posted May 03, 2016 11:08 PM
    Yes you can. Be sure they're running the same code and also that they share the same management VLAN.
  • 3.  RE: IAP-115 and IAP-225 In One Cluster
    Posted May 03, 2016 11:11 PM
    If you are not sure if they run the same code, would you still have the boxes that they came in? The labeling should be able to tell you.
  • 4.  RE: IAP-115 and IAP-225 In One Cluster
    Posted May 03, 2016 11:39 PM
