  • 1.  IAP
    Posted Apr 06, 2014 03:59 AM
    dear all
    i have some question about IAP ...
    my senareo :
    i was on demo with IAP 93 and it cant work for first time until it get IP address from the network ,the client didnot use DHCP on his network so
    1-can i configure some IAP in network with out using DHCP of network and DHCP of IAP Cluster ?
    say i have 8 IAP , can i give every one of them static ip address only ?
    thanks ,
    Best Regards,
  • 2.  RE: IAP
    Posted Apr 06, 2014 04:33 AM
    Hi your question is to have the IAP management IP to be static, if yes it can be done. I use DHCP first and once they are online, convert them to static according to your requirement.
  • 3.  RE: IAP
    Posted Apr 06, 2014 04:59 AM
    what if i have to configure 8 IAP on a new network and no DHCP on SW ,so to give every IAP Static IP and not need to run DHCP on IAP
    does i must have DHCP on network ?
    Does IAP have DHCP Server ?
    i worked on IAP 93 and i cant give ip to AP and i cant open dhcp pool from the IAP ?
    all my client need is to give every IAP static ip address and the user will get static ip address
    thanks for your help
    Ehab Atef
  • 4.  RE: IAP
    Posted Apr 06, 2014 08:53 AM
    Hi
    Each answer is written in RED.
    • does i must have DHCP on network ?
    no - if the first instantAP unit u deploy will not get a DHCP , it will use internal static ip (connect a console - and u will see the address)
    But , it much faster and easier to use vlan with DHCP on it. (if u dont got DHCP on that SW - u may use you LAPTOP as a DHCP server just for the provisiong time - use tftpd , here is a guide on how to configure tftpd to be a DHCP server - very simple:
    http://www.tricksguide.com/how-to-setup-a-tftp-server-tftpd32-windows.html
    • Does IAP have DHCP Server ?
    yes , it does.
    http://www.arubanetworks.com/techdocs/InstantMobile/Advanced/Content/Chapter18%20DHCPConfiguration/ConfiguringDHCPOtherMode.htm
    read more here:
    http://www.airheads.eu/t5/Aruba-Instant-Cloud-Wi-Fi/iap-virtual-controller-as-dhcp-sever/td-p/147902
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Defining-DHCP-Scope/td-p/54434
    • i worked on IAP 93 and i cant give ip to AP and i cant open dhcp pool from the IAP ?
    Why u cant? sure u can :)
    read more here:
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Instant-AP-IP-address-change/td-p/82920
    Hope it will give u some idea,on how to start config your instant enviroment.
    Have a gr8 weekend.
    Me
  • 5.  RE: IAP
    Posted Apr 07, 2014 02:40 AM
    you can give a static IP address to your IAP by stopping the boot process from CLI interface and doing this commands:
    # setenv ipaddr <IAP IP>
    # setenv netmask <IAP NETMASK>
    # setenv gatewayip <IAP DEFAULT GATEWAY>
    # save
    # reset
    [If you found my post helpful, please give kudos]
  • 6.  RE: IAP
    Posted Apr 07, 2014 02:43 AM
    The simple way is always the fastest way :)
    M.gallina method is fast and will give u the ability to start and use your VC as a Dhcp server for the rest of the AP that in the same segment.
  • 7.  RE: IAP
    Posted Apr 07, 2014 04:01 AM
    thank you all for your helps ...
