IAP-175 and IAP-93 in same cluster
  • 1.  IAP-175 and IAP-93 in same cluster
    Posted Feb 25, 2013 05:29 PM
    We got the following scenario, one cluster running 5 IAP-105 and another cluster running one IAP-175 and 5 IAP-93, the management is done via Uplink Management Vlan 500 instead of native on the second cluster.
    The IAP-93 are working fine and we have one 93 as VC, but the IAP-175 does not provision from that VC what are we doing wrong.
    Thanks!
  • 2.  RE: IAP-175 and IAP-93 in same cluster
    Posted Feb 25, 2013 05:42 PM
    Check in the INFO frame (in GUI) what is the country code that the VC 93 IAP is in? Is it the same country code like your iAP175 unit?
    *Check it - if it's not the same country code in both units - the iAP175 will not provision into this VC.
    *Make sure you are using the lastest available InstantAP OS version. (It's always good)
    Me.
  • 3.  RE: IAP-175 and IAP-93 in same cluster
    Posted Feb 25, 2013 08:08 PM
    Thats my picture! got stolen ;P  hehe
  • 4.  RE: IAP-175 and IAP-93 in same cluster
    Posted Feb 26, 2013 01:53 AM
    HaHA :) Google gave it to me ;)
  • 5.  RE: IAP-175 and IAP-93 in same cluster
    Posted Feb 26, 2013 03:00 PM
    Thanks a lot, i solved the issue!
