  • 1.  IAP - 175
    Posted Jun 14, 2012 04:50 AM
    Can IAP 175 do point to point bridging in between the building? Because i have go through the IAP (IAP - 105) OS web console configuration page but don't have such as setting to configure the IAP 175 as a point to point bridging.
  • 2.  RE: IAP - 175
    Posted Jul 03, 2012 08:58 AM
    LAN to LAN wireless bridging is not yet supported on IAP175.
    This can be accomplished with a pair of MST200's and it is supported on AP-175 with controller.
    Eric Johnson
    Product Manager
    Outdoor Solutions
    Aruba Networks
  • 3.  RE: IAP - 175
    Posted Sep 11, 2013 09:48 AM
    I know this post is a year old, but just wanted to check to see if a wireless bridge is now possible with an IAP-175 with the latest code.  It is just a basic point-to-point wireless bridge, not a mesh deployment, which would require MSR series routers.
    Is this now possible?
  • 4.  RE: IAP - 175
    Posted Sep 11, 2013 10:13 AM
    I believe this was added in v.3.1 back in Sept. '12.  Take a look at the IAP User's Guide for "Wired Bridging".
    If this is just a P2P link you might take a look at our MST200.  This is part of the AirMesh family and is a single-radio (5GHz) AP with an integrated high-gain directional antenna.  This is perfect for a P2P link and will be a better value in this case.
  • 5.  RE: IAP - 175
    Posted Sep 11, 2013 10:29 AM
    Thank you, Marcus.  The MST200 seems like a great solution.
    I've been checking the data sheets on the MST200.  Does it require a controller to function or can they run without a controller?
  • 6.  RE: IAP - 175
    Posted Sep 11, 2013 10:30 AM
    All AirMesh APs are autonomous.  No controller needed.
  • 7.  RE: IAP - 175
    Posted Sep 11, 2013 10:33 AM
    Perfect.  Just what I needed.  Thank you very much, Marcus.  I greatly appreciate it.
  • 8.  RE: IAP - 175
    Posted Sep 11, 2013 10:53 AM
  • 9.  RE: IAP - 175
    Posted Dec 28, 2013 01:14 AM
    as per arubapedia, iap-175 also support bridging.
