  • 1.  IAP-205 - 80Mhz channels
    Posted Jul 19, 2016 12:27 PM
    In a school enviroment with an IAP-205 in each classroom is it better to disable 80Mhz support and / or Very High Throughput?
    I am in the England.
    Jason
  • 2.  RE: IAP-205 - 80Mhz channels
    Posted Jul 19, 2016 12:32 PM
    In most environments it is recommended to disable 80MHz channels, but leave
    VHT enabled. You may want to work with your partner to design a solution for
    your environment.
  • 3.  RE: IAP-205 - 80Mhz channels
    Posted Jul 19, 2016 12:34 PM
    Thanks Tim.
    your environment.
