  • 1.  IAP-205 and IAP-305 mixing
    Posted Mar 08, 2017 12:41 PM
    It is my understanding that AP-205 model is being discontinued or has been?
    We have about 80+ IAP-205s (2 years old) that are being moved to new locations.. The new locations will be larger and we'll likely need to purchased more APs. The next comparable model is IAP-305.  I understand that they will function in the same cluster. Is there anything I need to be aware about to make sure we don't run into any issues?
  • 2.  RE: IAP-205 and IAP-305 mixing
    Posted Mar 08, 2017 02:02 PM
    What version of InstantOS you are currently running ?
    Get Outlook for iOS
  • 3.  RE: IAP-205 and IAP-305 mixing
    Posted Mar 08, 2017 02:30 PM
    The latest version, likely... We tend to update them as we see them come through..
  • 4.  RE: IAP-205 and IAP-305 mixing
    Posted Mar 08, 2017 03:09 PM
    Make sure that the IAP305s have the same code as the existing cluster otherwise those wont joint the cluster
    The IAP-305 required Aruba InstantOS 4.3.1.0 and up
  • 5.  RE: IAP-205 and IAP-305 mixing
    Posted Aug 08, 2017 09:23 AM
    Hi all,
    We've a cluster with iap 205 & iap 215 but iap 305 won't appear in the cluster.
    Our firmware is 6.4.4.8-4.2.4.6_58505
    Any idea?
  • 6.  RE: IAP-205 and IAP-305 mixing
    Posted Aug 08, 2017 09:31 AM
    Manually upgrade or downgrade your 305s on a different subnet to the 6.4.4.8-4.2.4.6_58505 release.  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=24665
    I was wrong.  The AP-305's minimum code level is 4.3.1.0  http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
    You will have to upgrade your cluster to this version, first before adding 305s....
