  • 1.  IAP-205 Network Expansion
    Posted Jun 18, 2021 09:38 AM
    Hi
    I have a network which has 3 IAP-205 AP's in it which I need to add a 4th AP to, does anyone know the options available that I can use to add an AP to the existing network?
    Ian Jefferson
  • 2.  RE: IAP-205 Network Expansion
    Posted Jun 18, 2021 11:47 AM
    You just need another IAP/UAP that can run the same version of code.
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: IAP-205 Network Expansion
    Posted Jun 18, 2021 12:28 PM
    Any hints as to where I can find out what is compatible/can run the same version of code?
    Ian Jefferson
  • 4.  RE: IAP-205 Network Expansion
    Posted Jun 18, 2021 01:02 PM
    Start here, and filter by the code you are running / want to run. You can also choose multiple AP models, and it should filter versions of software that they can use together: https://asp.arubanetworks.com/downloads;products=Aruba%20Access%20Points
    Dustin Burns
