  • 1.  IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 07, 2018 11:27 PM
    My AP stuck in a boot loop.
    Please help me. Thank you!
    APBoot 1.5.3.4 (build 43264)
    Built: 2014-04-16 at 15:38:45
    Model: AP-22x
    CPU0:  P1020E, Version: 1.1, (0x80ec0011)
    Core:  E500, Version: 5.1, (0x80212051)
    Clock:
           CPU0: 800 MHz
           CPU1: 800 MHz
           CCB:  400 MHz
           DDR:  333.333 MHz (666.667 MT/s data rate) (Asynchronous)
           LBC:   25 MHz
    L1:    D-cache 32KB enabled
           I-cache 32KB enabled
    I2C:   ready
    DRAM:  Configuring DDR for 666.667 MT/s data rate
    DDR:   512 MB (DDR3, 32-bit, CL=5, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2:    256 KB enabled
    Power: DC
    PCIe1: RC, link up, x1
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  43a2 00002   03 80000004 00000000 80200004 00000000
    PCIe2: RC, link up, x1
           00  00  14e4  43a1 00002   03 a0000004 00000000 a0200004 00000000
    Net:   eth0, eth1
    Radio: bcm43460#0, bcm43460#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xee000000
    Invalid image format version: 0xffffffff
    Checking image @ 0xeee00000
    Copying image from 0xeee00000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Aruba Networks
    ArubaOS Version 6.3.1.0 (build 39345 / label #39345)
    Built by p4build@tortuga on 2013-08-08 at 16:30:24 PDT (gcc version 4.5.1)
    Memory: 510348k/524288k available (8348k kernel code, 13940k reserved, 540k data        , 352k bss, 5008k init)
    Processor 1 found.
    Brought up 2 CPUs
    PCI: Probing PCI hardware
    pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    pci 0000:00:00.0: enabling device (0106 -> 0107)
    pci 0001:02:00.0: enabling device (0106 -> 0107)
    ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    /proc/gfar_eth0_stats created
    /proc/gfar_eth1_stats created
    Enabling watchdog on CPU 1
    Enabling watchdog on CPU 0
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: active-standby
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 66, num_radios 2 (jiffies 3213)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is up
    ASAP Slowpath initialized
    Starting watchdog process...
    Getting an IP address...
    PHY: eth1 (mdio@ffe24000:01) - Link is Up - 1000/Full
    bonding: bond0: link status definitely up for interface eth1.
    bonding: bond0: making interface eth1 the new active one.
    bonding: bond0: first active interface up!
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.10.10.54 255.255.255.0 10.10.10.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    After I manual config DNS, factory_reset, purge enviroment... I got other error
    Model: AP-22x
    Clock:
           CPU0: 800 MHz
           CPU1: 800 MHz
           CCB:  400 MHz
           LBC:   25 MHz
    I2C:   ready
    Flash: 32 MB
    L2:    256 KB enabled
    Power: DC
    Net:   eth0, eth1
    Signer Cert OK
    Policy Cert OK
    Aruba Networks
    Memory: 510348k/524288k available (8348k kernel code, 13940k reserved, 540k data, 352k bss, 5008k init)
    Processor 1 found.
    Brought up 2 CPUs
    apfcutil: sector CACHE: Cache uninitialized
    apfcutil: sector RAP: Cache uninitialized
    apfcutil -c RAP: Uninitialized. Initializing.........
    apfcutil: sector MESH Prov: Cache uninitialized
    AP xml model 66, num_radios 2 (jiffies 4696)
    192.168.1.41 255.255.255.0 192.168.1.1
    Running ADP...Done. Master is 192.168.1.2
    wifi0: AP type AP-225, radio 0, max_bssids 16
    wifi1: AP type AP-225, radio 1, max_bssids 16
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    ?: Permission denied
    ~ # help
    help: Permission denied
    The system is going down NOW !!
    Sending SIGTERM to all processes.
    Restarting system.
     I've tried tftpboot but no luck
    apboot> tftpboot
    eth0: link down.
    eth1: link up, speed 1 Gb/s, full duplex
    DHCP broadcast 1
    DHCP IP address: 192.168.1.42
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.1.1
    DHCP DNS server: 192.168.1.1
    DHCP DNS domain:
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master. to 192.168.1.1
    Using eth1 device
    TFTP from server 192.168.1.2; our IP address is 192.168.1.42
    Filename 'e500.ari'.
    Load address: 0x8000000
    Loading: T T T T T
    Retry count exceeded; starting again
    eth0: link down.
    DHCP broadcast 1
    DHCP DNS domain:
    ADP broadcast 3
    ADP multicast 4
    ADP broadcast 4
    ADP multicast 5
    ADP broadcast 5
    Using eth1 device
    Loading: T T T T T
    eth0: link down.
    DHCP broadcast 1
    DHCP DNS domain:
    ADP multicast 6
    ADP broadcast 6
    ADP multicast 7
    ADP broadcast 7
    ADP multicast 8
    Using eth1 device
    Loading: T T T T T
    eth0: link down.
  • 2.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 08, 2018 10:11 AM
    You list both IAP205 and AP225, is this environment running Instant or is there an AOS controller for the AP to connect to?
    The first set of logs show the AP not discovering the controller. It appears that after you fixed the DNS settings, the AP did discover the master and attempted to connect.
  • 3.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 08, 2018 11:59 AM
    I have an IAP-205 in standalone mode. I just tried to add an AP-225 to extend wifi coverage but it's stuck in a boot loop.
    I think AP-225 found virtual controller but can not connect.
    What should I do?
  • 4.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 08, 2018 12:04 PM
    What should I do?
    The AP225 can't find a virtual controller (as in an Instand based virtual controller). What is the device that's operating as 192.168.1.2? If you have an IAP operating as standalone, the AP225 will not work along with it unless the AP-225 is also running Instant firmware. You would need an IAP225 for that, as it's not possible to load Instant firmware to an AP that did not originate as an Instant model.
  • 5.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 08, 2018 12:10 PM
    A AP225 will not join a Virtual Controller/IAP cluster. You would need an IAP225 for this to work. If you check the back of the 225, you can see if it is an AP or IAP.
  • 6.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 08, 2018 09:19 PM
    @cclemmer: Do you mean AP-225 cannot be controlled by virtual controller?
    @zalion0: My AP-225 is non-instant, it's AP not IAP. It can working with IAP-205, isn't is?
    My config as below:
    IAP-205: OS ArubaInstant 6.4.1, IP 192.168.1.40, Virtual controller running on it, VC's IP 192.168.1.2.
    AP-225: OS 6.3.1, IP 192.168.1.41 <= just tried to add but got error.
  • 7.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 09, 2018 12:51 AM
    That is correct an AP225 cannot be managed by an IAP225 or join an an IAP cluster. A IAP225 can be converted to an AP225 and managed by a physical controller but an AP225 cannot be converted to an IAP225.
    Sent from my iPhone
  • 8.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 09, 2018 10:01 AM
    Yes, that is correct. For the AP to be controlled by an Instant virtual controller, you would need the IAP-225 instead.
  • 9.  RE: IAP-205 (OS 6.4.1) with AP-225 (OS 6.3.1)
    Posted Aug 09, 2018 07:16 PM
    Thank you so much!
    I misunderstood that non-instant AP(s) can be controlled by a virtual controller.
