This is a weird one!
24 IAP-205's all installed on the same network, the netwrok is flat.
2 of the IAP-205's will not join the cluster, they boot up and the radio lights are amber. I take down these IAP's and repalce them with 2 option IAP-205's and everythign is fine, they come up and join the cluster.
I can factory reset the 2 IAP's that won't join and provision them speratley as you would a new installation on a seperate network, I reset them back to factory and try to get them to join the exisitng cluster and they won't join... reset them again they still won't join the cluster nothing will make them join!
In the end I gave up and left the 2 other IAP-205's working on the customers site.
Where did I go wrong?
