  • 1.  IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 02:22 AM
    Hi Aruba Guro's,
             We have this new IAP225 and seems that cannot joins this to our existing network. Is anybody have some guide on how to make this work? Setup is very simple, We have our DHCP server and this IAP225 will be used as AP only. We have 3 IAP225 and this must work together.
    Your help will be much appreciated. Thanks.
    #AP225
  • 2.  RE: IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 02:24 AM
    What version are you running? 4.0.0.4 is the recommended version for IAP225 at the current time.
    Do you have APs other than 225 in your network? What specific issue are you having?
    Yan
  • 3.  RE: IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 02:42 AM
    Hi Yan,
               Thanks for your reply. Currently we dont have another Aruba AP. We are using Cisco currently and want to change to this IAP225. Please see attached screenshot.
               After adding new SSID, still cannot connect to the network. Tried to connect to newly created SSID, but after a minute or two the Ip add will change to 169 something.
  • 4.  RE: IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 02:48 AM
    Can you post the config you have on the iAP?
  • 5.  RE: IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 03:26 AM
  • 6.  RE: IAP 225 Cannot Connect to existing Network
    Posted Mar 18, 2014 03:32 PM
    Please upgrade this AP and retest...also post the entire config found in the Maintenance link
