  • 1.  IAP 225 is not joining existing network
    Posted Sep 09, 2022 10:43 AM
    I have an office with an IAP 225 already running and I'm adding another IAP 225.  I have assigned an IP address and upgraded both APs to 8.6 firmware.  From the new AP I can ping the Default Gateway, the current AP, and the Virtual Network IP.  It seems to boot up into standalone mode regardless of what I do.
    Looking for help in troubleshooting this.  I've attached the boot log and the running config from the console, but can grab other info if necessary.
    Joel
    Attachment(s)
    txt
    AP-Startup.txt   11 KB 1 version
  • 2.  RE: IAP 225 is not joining existing network
    Posted Sep 09, 2022 06:13 PM
    was that IAP-225 in standalone mode before you upgraded?
    Also is E1 port connected? if so can you disconnect it and reconnect the cable to E0.
  • 3.  RE: IAP 225 is not joining existing network
    Posted Sep 10, 2022 02:55 AM
    Hi Joel.
    In the boot prompt check it AP is setup as standalone.
    Use printenv command to list the environmental variables and look for "standalone_mode" variable. From CLI you can use show ap-env to check some of the environmental variables.
    # printenv
    standalone_mode = 1
    If you find it, just set it to 0 with
    # setenv standalone_mode 0
    # saveenv
    If this won't help, boot AP and go to CLI and setup your country code with
    # virtual-controller-country <your country code>
    Save the settings and reboot.
    ​​​​Best, Gorazd
