  • 1.  IAP-225-RW APIN0225 with Dell Label
    Posted Apr 10, 2021 03:16 AM
    i have IAP-225-RW APIN0225 with Aruba Label, i want to buy
    another one with Dell Label.
    This works together or can i flash the Dell AP that it work with the Aruba labeled?
    cu
    Gregor Hekro
  • 2.  RE: IAP-225-RW APIN0225 with Dell Label
    Posted Apr 10, 2021 06:37 PM
    the OEM APs do run different firmware. it is better not to mix them.
  • 3.  RE: IAP-225-RW APIN0225 with Dell Label
    Posted Apr 11, 2021 01:42 AM
    You can flash the Dell one with Aruba firmware.  Technically you won't be able to raise a support case if you do so, but if it is just for yourself, should be fine.
    Michael Clarke (Aruba)
  • 4.  RE: IAP-225-RW APIN0225 with Dell Label
    Posted Apr 11, 2021 04:09 AM
    Ok thanks when this works great :-)
    Gregor Hekro
