  • 1.  IAP-303 Band Steering
    Posted May 12, 2019 03:04 AM
    I'm using iAP-303 as my access point. I have several devices capable of handling 5Ghz connectivity, but everytime that devices connect, the AP always steering them to 2.4Ghz.
    I've already set band steering mode to Prefer 5Ghz, but still no luck. Is there any settings that I need to change ?
    Thanks.
  • 2.  RE: IAP-303 Band Steering
    Posted Jul 26, 2019 11:22 PM
    The general practice is to ensure that the max tx power for 2.4GHz radio is atleast 9dB less than the min tx power of 5Ghz radio. assumig you ar running the new WebUI,  you can change these settings from
    Configuration->RF->Show advance options->Radio->Default
  • 3.  RE: IAP-303 Band Steering
    Posted Jul 27, 2019 01:00 AM
    Thanks @ariyap.
