Become a Member
Hi all,
Some of our IAP 305 (IAP-305-RW) emit a red-solid light corresponding to the System Status LED, while the Radio Status LED is green. In the Aruba Guide there is only indicated that it is a System Error Condition, what does it mean? What is it due to?
Thanks!
Have you got a console cable to attach and determine if there is any output? Is the eth0 interface running at 100M as opposed to 1000M?
If the LED is indeed red and not amber, this is not an expected operating (or error) mode.
Is the AP operational?
Amber would simply indicate that the POE source is limited (class 3), which is not a serious issue. Red indicates a serious problem.
