  • 1.  IAP-325 Beaconing APB: Disabled
    Posted May 15, 2018 05:33 PM
    Hi
    I have a problem with an IAP-325 apparently I have everything well configured but for some reason I can not see the beacon and when I execute the debug commands I only realize that the beacon is off or does not appear.
    What I have noticed is that side of the state of beaconing in the configuration appears (APB: disabled), does anyone know what this refers to or what I have to do?
    Output of debug commands:
    5/15/2018 13:39:16 PM Target: PruebaAP Command: show ble-config
    BLE Configuration
    Item Value
    Authorization Token eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJsIjo1NjUyMjA0OTc0MjQzODQwLCJ0IjoxNTI1OTY3NzMwfQ.AIhgzGzwunzwfkznlwFlDovtJGSWqBoH6eeC8Fc3Bv0
    Endpoint URL https://edit.meridianapps.com/api/beacons/manage
    Update Intvl (in sec) 600
    Operational Mode beaconing
    Mgmt Server
    Mgmt Handshake Server
    Mgmt Handshake Token
    Mgmt Location Id
    5/15/2018 13:38:12 PM Target: PruebaAP Command: show ap debug ble-connect
    * About to connect() to edit.meridianapps.com port 443 (#0)
    * Trying 216.58.193.51...
    * Connected to edit.meridianapps.com (216.58.193.51) port 443 (#0)
    * successfully set certificate verify locations:
    * CAfile: /etc/pki/tls/certs/ca-bundle.crt
    CApath: none
    * CyaSSL: Connecting to edit.meridianapps.com:443
    * SSL connected
    > POST /api/beacons/manage HTTP/1.1
    Host: edit.meridianapps.com
    Content-Type: application/json
    Authorization: MERIDIAN eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJsIjo1NjUyMjA0OTc0MjQzODQwLCJ0IjoxNTI1OTY3NzMwfQ.AIhgzGzwunzwfkznlwFlDovtJGSWqBoH6eeC8Fc3Bv0
    Accept: application/vnd.meridian.v1+json
    Content-Length: 225
    * upload completely sent off: 225 out of 225 bytes
    < HTTP/1.1 200 OK
    < Content-Language: en
    < Vary: Accept, Accept-Language, Cookie
    < ETag: "dc4e217787010f5fd69fdc6d3f0d3631"
    < Allow: POST, OPTIONS
    < Access-Control-Allow-Credentials: false
    < Access-Control-Allow-Origin: *
    < Content-Type: application/json; application/vnd.meridian.v1+json;
    < X-Meridian-Media-Type: version=v1
    < X-Cloud-Trace-Context: 02e93c83d1288a87cb3c504e7cc083ac
    < Date: Tue, 15 May 2018 19:19:01 GMT
    < Server: Google Frontend
    < Content-Length: 32
    * Connection #0 to host edit.meridianapps.com left intact
    5/15/2018 13:36:48 PM Target: PruebaAP Command: show ap debug ble-config
    BLE Configuration
    Item Value
    BLE Supported ONBOARD
    BLE HW Type BT-AP320
    Master IP 192.168.1.180
    BLE Ready Yes
    Beacon Mgmt Update Intvl (in sec) 600
    APB Info Update Intvl (in sec) 362 (1532/1503)
    BLE debug log Enabled
    Operational Mode Beaconing (APB: Disabled)
    Message Selector 0xffff (APB: 0x0)
    AP USB Power Override Disabled (-1)
    Uplink Status Up (APB: -NA-)
    APB Connection Status 0
    Last BLE Device Update Attempted 00:00:00:00:00:00
    Last AP to APB Message Time 1970-01-01 00:00:00
    Last Update to Endpoint Time 2018-05-15 19:19:00
    Log Levels Available { All(0xffff), Info(0x04), Warning(0x02), Error(0x01), Ageout(0x08), BMReq(0x10), FW-Upgrade(0x20), FW-UpgradeErr(0x40), CfgUpdate(0x80), CfgUpdateErr(0x100), Beacon(0x200), BcnTLV(0x400), BcnErr(0x800), APB(0x1000), AssetUpdate(0x2000), None(0x00) }
    Current Log Level { 0x1e1 : Error(0x0001), FW-Upgrade(0x0020), FW-UpgradeErr(0x0040), CfgUpdate(0x0080), CfgUpdateErr(0x0100) }
    Log Mac Filter None
    Bundled BluOS Images Bank A(/aruba/bin/UpgradeImage_AP_OAD-A_1.2-19.bin) Bank B(/aruba/bin/Beacon_AP_OAD-B_1.2-19.bin)
    Note: Uplink status is applicable only for Controller with Dynamic Console operational mode.
    For APBs of type LS-BT1USB, applied operational mode is Beaconing if ap system profile setting is either Persistent or Dynamic.
    Note: Setting Message Selector value to 0x0 will cause the APB to function improperly. Use the knob with caution.
    Note: Message Selector Bits: All(0xffff), V0 Scan (0x01), V1 Scan (0x02), UI Scan (0x04), Proximity Advert (0x08), IBeacon (0x10), Heartbeat-1 (0x20), Heartbeat-UI (0x40), Upg Ack (0x80), Heartbeat-2 (0x200), Generic Scan (0x400), Generic Advert (0x800), Tag V1 Scan (0x1000), Tag V1 Advert (0x2000)
    5/15/2018 13:36:31 PM Target: PruebaAP Command: show ap debug ble-table all
    Total BLE devices:0
    Note: Battery level for LS-BT1USB devices is indicated as USB.
    Note: Uptime is shown as Days hour:minute:second.
    Note: Last Update is time in seconds since last heard update.
    Status Flags:L:AP's local beacon; I:iBeacon; A:Beacon management capable
    :H:High power beacon; T:Asset Tag Beacon; U:Upgrade of firmware pending
  • 2.  RE: IAP-325 Beaconing APB: Disabled
    Posted May 16, 2018 09:55 AM
    What exactly are your trying to achieve? The AP Beacon (APB) can be used as a location/proximity beacon, for asset tracking, for beacon management of battery beacons or as a wireless console port.
    The beacon is disabled by default (at least in the firmware I tried), and can be enabled under More -> Services -> RTLS -> Aruba:
    If you put it to Beaconing, it will be enabled with a delay of about 10-15 seconds, and you should see the beacon up:
    ac:a3:1e:cd:47:2c# show ap debug ble-config
    BLE Configuration
    Item                               Value
    Operational Mode                   Beaconing (APB: Beaconing)
  • 3.  RE: IAP-325 Beaconing APB: Disabled
    Posted May 16, 2018 03:24 PM
    Hi Herman
    thanks for your answer, actually if I know everything you mention, I want to use it for location but as you can see in the post, the beacon despite having it in beaconing does not turn on for some strange reason.
    I have installed more than 200 beacons on AP, USB or battery and it is the first time this happens to me with an AP 325 beacon.
    normally in the output of the command  "show ap debug ble-config" it appears like this:
    but in this case it appears like this:
    already probe it in IAP mode and in CAP mode, the result is the same.
    Regards
  • 4.  RE: IAP-325 Beaconing APB: Disabled
    Posted Aug 16, 2018 09:16 AM
    same issue overhere, did you found a solution? or is the AP broken?
    Kind regards,
    Thomas
  • 5.  RE: IAP-325 Beaconing APB: Disabled
    Posted Aug 16, 2018 10:09 AM
    Finally, the AP was broken... TAC team sent me another AP after 4-5 hours of supports to try make it work again...
    Question: Before your AP beacon stop working, did you've swipe out the AP beacon outside of the map while you try to configure it in the Aruba Beacon App (Manipulation error) ?
    Cheer's,
    Simon Rousseau
  • 6.  RE: IAP-325 Beaconing APB: Disabled
    Posted Aug 16, 2018 10:11 AM
    They never appeared in the meridian editor.
    I will initiate an RMA
    Kind regards,
    Thomas
  • 7.  RE: IAP-325 Beaconing APB: Disabled
    Posted Aug 16, 2018 10:47 AM
    Hi Thomas,
    The support team will certainly be able to help you solve your case.
    P.S. I'm pretty sure you already know this... but, just in case:  you should configure your AP beacons throught the Aruba Beacon mobile app before it will appear in the meridian web editor.
    Simon Rousseau
    simon@rioh.io
  • 8.  RE: IAP-325 Beaconing APB: Disabled
    Posted Aug 16, 2018 11:04 AM
    Indeed, but of all my APs configured (+40) only 2 are not working, and even not seen on https://edit.meridianapps.com while other are just apearing in the online meridian portal when I have configured my meridian settings on the controller side.
    Thanks anyway, I will open a ticket with TAC
