This unit left the factory as an IAP-325 (label screenshot below). Somewhere in it's deployment line, it was converted to an external controller based AP.
Fortunately, the reseller has agreed to accept it back. Thanks for your support _()_
Original Message:
Sent: Jun 22, 2023 01:52 AM
Subject: IAP-325 factory reset failing
that indicates, this is a controller based AP not an instant AP, and you need a controller for it.
if you look at the back of the AP, you should see a sticker what says AP-325 right?
Original Message:
Sent: Jun 22, 2023 12:36 AM
I bought a RJ45/USB A cable at Amazon.
Here is a screen capture of the console messages -- looks like it is trying to find the DNS name of the master controller "aruba-master."
Looks like this IAP-325 was converted from an Instant AP to an AP controlled by an external controller. Am I on the right track?
Also how to convert from this version to an Instant version?
Retry count exceededDNS request 1 for aruba-master. to 172.17.2.1T T T Retry count exceeded; starting againeth1: link downeth0: link up, speed 1 Gb/s, full duplexDHCP broadcast 1*** Unhandled DHCP Option in OFFER/ACK: 28*** Unhandled DHCP Option in OFFER/ACK: 28DHCP IP address: 172.17.2.20DHCP subnet mask: 255.255.255.0DHCP def gateway: 172.17.2.1DHCP DNS server: 172.17.2.1DHCP DNS domain: ADP broadcast 28ADP multicast 29ADP broadcast 29ADP multicast 30ADP broadcast 30Retry count exceededDNS request 1 for aruba-master. to 172.17.2.1T T T
ArunK--
ArunK
Original Message:
Sent: Jun 19, 2023 07:09 PM
Thanks for confirming the serial port settings. I have ordered a RJ45>USB serial cable.
I'll post my findings from the console for further help.
ArunK
Original Message:
Sent: Jun 19, 2023 06:34 PM
yes the setting are 9600-8N1 and i think this is the pin out.
Original Message:
Sent: Jun 19, 2023 01:14 PM
Thanks for your quick reply.
Yes -- I did connect the PoE cable to the ENET0 port.
Is the RJ45 console cable standard or do I need a Aruba specific console cable?
I'll be using minicom (Linux desktop).
Will this setting work -- 9600, 8N1?
Thanks.
ArunK
Original Message:
Sent: Jun 19, 2023 02:33 AM
I am assuming you have connected the E0 to the power injector and not E1.
also just connect a consle cable and see whats going on.
Original Message:
Sent: Jun 19, 2023 02:20 AM
I have bought a used (off lease) IAP-325 APs. I have configured the LAN DHCP server to give out "assigned" IPs based on the APs MAC address, in my case 172.17.2.20.
The device is powered by a single port Gigabit PoE injector (30W), the LAN port of the injector is connected to the "lab" LAN segment of my network.
I have followed the instructions on this online manual to do a factory reset.
https://www.arubanetworks.com/techdocs/Instant_87_WebHelp/Content/instant-ug/iap-mainten/reset-rap-or-cap.htm?Highlight=reset
With the reset button pressed, when I insert the LAN cable (PoE), the AP powers ON with the power LED flashing *red* for about 2 seconds and then it fast blinks in green color for about 2-3 seconds. After that the power LED blinks slowly (green color).
The DHCP server's lease file shows that 172.17.2.20 was assigned to the AP.
However, ping and 'nmap -sV -A -T5 -sT 172.17.2.20' shows the host '172.17.2.20' is down.
FWIW. I have left the device powered up for 12+ hours and the power LED does a slow blink (green)
What am I missing in the reset process? Thanks so much!
ArunK
