  • 1.  IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 05:24 PM
    On an IAP-325, I upgraded the firmware to 8.11.2.1_88699 (from 8.10) via the WebUI interface.
    After the upgrade, I did a factory reset on the device for installation at another location.
    On boot, I noticed a couple of quirks:
    1. The web username: admin and password <device serial number>  does not work.  I tried the older "admin/admin" that logged me into the device!
    2. At first login, the device presents the country code selection.  I select the US as the country code and click the "OK" button.  Nothing happens! (screenshot below)
    Any suggestions on how to make it operational again would be sincerely appreciated.
    ArunK
  • 2.  RE: IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 05:46 PM
    [SOLVED]
    Clicking on the "Upgrading your AP" link, I was able to navigate the "Firmware" page.  Luckily I have an 8.7 factory image.  I applied it and the device "upgraded" successfully.  I am back to an 8.7 "factory" image.
    ArunK
  • 3.  RE: IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 05:49 PM
    The 325 is parked on 8.10, I'm a bit surprised you got an 8.11.anything image to load.
    Carson Hulcher, ACEX#110
  • 4.  RE: IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 06:11 PM
    Thanks for reading and replying.
    Yes, I was surprised as well.  I had tried to upgrade to 8.11 earlier but on reboot, the device would revert to 8.10.  So when I did a factory reset and tried to log in, I was surprised it would not accept the device serial number as the password.  It was sheer brute force that admin/admin worked and then I noticed it was on 8.11.
    Anyway, I was able to revert to an 8.7 factory image and will keep it there until a newer "factory" image is released.
    ArunK
  • 5.  RE: IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 07:29 PM
    The firmware page allows an upgrade to 8.11 from 8.7 (screenshot below).  Shouldn't it be limited to 8.10 if the 325s are parked on 8.10?
    ArunK
  • 6.  RE: IAP-325 WebUI does not accept the Country code (firmware 8.11.2.1_88699)
    Posted Feb 05, 2024 07:33 PM
    Edited by schmelzle Feb 05, 2024 07:33 PM
    Unfortunately, the AP-325 shares a platform image (Hercules) with another AP that is supported in 8.11. The code to detect if there is an update available is based on the platform image.
    Josh
