  • 1.  IAP 335 joining current group
    Posted Oct 24, 2016 03:56 PM
    Good day all..  i just purchased 2 IAP 335's and pluged one in and expected it to autojoin as usual to my current group.  i currently have IAP 105's, 135's and 225's and they all seem to join fine. however the 335 seems to be having a problem joining.   the power light blinks green but never seems to ready.  all other IAP's are on firmware 6.4.2.6-4.1.3.0_54915..  the 335's are on 6.5 .. is there something i need need to do to get the 335 to join?
  • 2.  RE: IAP 335 joining current group
    Posted Oct 24, 2016 04:03 PM
    You need to be running -4.3.0.0 and up for the 335 to join
    Get Outlook for iOS
  • 3.  RE: IAP 335 joining current group
    Posted Oct 24, 2016 04:06 PM
    thanks you for your quick reply.. where do i get the 6.4.3 firmware for the other IAP's.   i have searched but can not seem to find newer firmware than what im already running.
  • 4.  RE: IAP 335 joining current group
    Posted Oct 24, 2016 07:48 PM
