IAP-535s do not join cluster with IAP-515
  • 1.  IAP-535s do not join cluster with IAP-515
    Posted Apr 11, 2022 10:44 AM
    IAP-515 are running 8.7.1.8_83050
    IAP-535 are running  8.7.1.3_79817
    Most of IAP-535s are shown as Offline in Aruba Central.
    I can log in via ssh and I've managed to run it as VC by running command "iap-master".
    I have in total 4 IAP-535 and 5 IAP-515 and I think I will need to run only one VC however IAP-535 do not seem to join other VC properly.
    I'm attaching a "show tech-support" from new IAP-535 which is not master.
    Anthony Gabriel
    Attachment(s)
    txt
    WAP-17.txt   127 KB 1 version
  • 2.  RE: IAP-535s do not join cluster with IAP-515
    Posted Apr 11, 2022 10:50 AM
    Edited by DB86 Apr 11, 2022 10:49 AM
    The firmware need to be the same for the 535s and 515s to cluster together. You will need to manually upgrade one of the 535s and add it to the cluster. Once it is joined, the remaining can join, download the firmware from the first 535, and upgrade themselves. They will then reboot and join the 515 cluster.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
