  • 1.  iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 29, 2015 11:44 AM
    Hi All,
    For some reason, historically, our client never had background spectrum monitoring enabled on there iAPs, so I have an exercise to enable this.
    They are running alot of iAP 93's and we're seeing alot of memory threshold alerts in airwave for them, usually around 85-90% (threshold is 77%).... so my question is, will enabling background monitoring push that memory usage up further, and am I likely to cause more problems on the 93's?!
    Cheers,
    Danny
  • 2.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 29, 2015 11:57 AM
    Dannyg81,
    What version of Instant code are you running on your AP93?
  • 3.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 29, 2015 12:04 PM
    I've just upgraded them to 6.4.2.6-4.1.1.8 actually, I believe that is the latest release?!
    Cheers,
    Danny
  • 4.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 29, 2015 12:16 PM
    The IAP-93 is probably the AP platform with the least memory of all access points.  I would not run hybrid spectrum full-time as a result.  You will get memory errors, but it should reclaim it.  Again, you should not run hybrid spectrum full time.
  • 5.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 29, 2015 12:18 PM
    Thanks, I thought as much but wanted to double check so I can go back to the customer with a tangible reason not to on the 93's.
    Thanks!
  • 6.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 30, 2015 11:27 AM
    I thought that feature was disabled in the 93 precisely because of the memory issues several revisions ago.
  • 7.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 30, 2015 12:24 PM
    It was not.  From the release notes:
  • 8.  RE: iAP 93 memory usage enabling background spectrum monitoring
    Posted Oct 30, 2015 12:28 PM
    Cool!
    We were unhappy when it went away, glad it was reintroduced. Missed that in the release notes.
    I'll go turn it on...
