Trying to configure (3) IAP 93 in a new home and looking for some support on best configuration pratices and also see what needs to be done to get Sonos speakers working. They dont seem to be able to connect.
SO far - connected the 3 devices and configrued the VC and did some basic settings through the GUI,
- Enable Broadcast filter if you are able to, one of the biggest issues on the wireless network is the broadcast.
- Enable Broadcast Filter ARP
- Enable Dynamic Multicast Optimization
- Enable AirGroup
- Set local probe to 20dBm
Just one SID as employee, Network assigned, WPA2 and access restrictions. everything on just a single network 192.168.200.x
I think they are running 6.2 something firmware which think I read a new version is out there but not sure where to get that yet.
if you cant tell its my first time messing with the aruba devices and apprcate and help you can provide
thanks in advance
LA
