  • 1.  IAP ARP Spoofing/ ARP Poisoning Question
    Posted Jan 31, 2017 07:31 AM
    Hi all,
    Regarding this topic i have some questions that i hope some guru can help me.
    I have enabled in my test IAP the following:
    attack
    drop-bad-arp-enable
    fix-dhcp-enable
    poison-check-enable
    From what i have read this should stop arp poisoning in a SSID.
    The problem is that i have done some tests (using arpspoof in kali linux) and although i cant spoof a connected client in a SSID i can spoof the Default-gateway to the other clients.
    Example: (clients on same SSID, Default GW a router)
             DefaultGW
    client X --IAP;----- Client Y
                Client Z
    Client X cant "tell" client Y or the gateway via arp spoof that client z ip is at his mac.
    BUT Client X can tell client Y and Z that the ip of the gateway is at his mac , so he can receive packets from client Y,Z (half mitd ???)
    So the big question is if this is normal behaviour and i should just check somewhere the the snmp traps generated by "poison-check-enable" or there is another way to do this or a bug ??
    ps - "I tested and deny inter user traffic stops this, but it also stops all traffic :) "
    Vss
  • 2.  RE: IAP ARP Spoofing/ ARP Poisoning Question
    Posted Mar 03, 2017 08:10 AM
    I assume that you are not seeing anything in "show attack stats"?  Do you see the ARP packet counter increasing?
    # show attack stats
    attack counters
    Counter Value
    arp packet counter 152
    drop bad arp packet counter 0
    dhcp response packet counter 0
    fixed bad dhcp packet counter 0
    send arp attack alert counter 0
    send dhcp attack alert counter 0
    arp poison check counter 0
    garp send check counter 0
    To be honest, whether you are spoofing the GW or another client, then (IMHO) the effect for a MITM attack should be the same.
    I have tested this in the lab and I see something that strikes me as strange:
    # show arp
    IP address HW type Flags HW address Mask Device
    10.10.51.5 0x1 0x2 24:a0:74:xx:xx:xx * br0
    10.10.51.1 0x1 0x2 24:a0:74:xx:xx:xx * br0
    I have obfuscated the last bytes of the test PC's MAC@, but as you can see the client IP is 10.10.51.5 and is spoofing the def. GW's address (10.10.51.1 = upstream router) and the IAP has updated its ARP table with the test PC's MAC@.  On another test PC connected to the same WiFi network and subnet, the def. GW is also seen as 24:a0:74:xx:xx:xx, so by definition, the ARP poisoning can be considered to have worked.
    As the test PC is a WiFi client, I would have thought that should be enough to trigger alarm bells in the IAP i.e. IAP should think "how is my def. GW coming from a WiFi client?"   A pkt debug on the IAP confirms this:
    Received packet from bond0 (timestamp (117-2-3 12:52:35:455531))
    [asap_firewall_forward(5457):firewall entry] len 60, vlan 0, egress CP, ingress bond0:
    #mac: etype 0806 smac 24:a0:74:xx:xx:xx dmac ff:ff:ff:ff:ff:ff
    #arp: opcode response(2), sip 10.10.51.1, tip 0.0.0.0, smac 24:a0:74:xx:xx:xx, tmac ff:ff:ff:ff:ff:ff
    [asap_firewall_forward(5633):vlan decision] len 60, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6142):looking up pkt ingress/src bridge entry 24:a0:74:xx:xx:xx] len 60, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6182):Found ingress/src bridge entry 24:a0:74:xx:xx:xx rechable via bond0] len 60, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6473):bridge section, looking for dst bridge entry ff:ff:ff:ff:ff:ff] len 60, vlan 1, egress CP, ingress bond0:
    [asap_firewall_forward(6569):Unable to find dst bridge entry ff:ff:ff:ff:ff:ff, flood to VLAN 1] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6604):session section] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(6851):fastpath session returned 0 opcode 0] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(7421):route section] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(7471):cp route section] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_forward(7789):forward section] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(9215):flooding] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(9419):checking dev2 bond0] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_flood(9988):stack section protocol=0x806, type=1] len 60, vlan 1, egress vlan 1, ingress bond0:
    [asap_firewall_send_up_stack(3697):going to stack protocol:0x806 type:1] len 46, vlan 1, egress vlan 1, ingress br0:
    This needs some further testing, because here the test PC's and IAP are all using the same subnet (def. VLAN 1).
    Do you have a TAC case open for this?
    David
  • 3.  RE: IAP ARP Spoofing/ ARP Poisoning Question
    Posted Jul 24, 2017 03:25 AM
    Can you let me know if this is resolved and what the resolution is please?
    I am thinking if recommending enabling:
    • Drop bad ARP
    • Fix malformed DHCP
    • ARP poison check
    on our Aruba instant network, but your article has raise some concerns.
    Thanks.
  • 4.  RE: IAP ARP Spoofing/ ARP Poisoning Question
    Posted Jul 24, 2017 05:33 AM
    Hi, There is no problem in enabling them. Just know that the "anti-spoof" mechanism will only work if the attacker spoofs ip´s of connected clients to the IAP, so in my view it only "half" works.
    Example : Clients: A,B,C
    B spoofs A to C -> The IAP will drop this spoof packets
    B spoofs A to default-GW -> The IAP will drop this spoof packets
    B spoofs Default-GW to A -> this will work and A will send packets that should go to the DG to B (so spoof was sucessfull )
    So in this scenario the attacker would be able to receive packets from A to the GW but not sent to A from the GW (half spoof???).
    Workaround -> If you enable "deny-inter-user-bridging" spoof wont work (i have done this in our guest network)
    PS - I have requested full anti-spoof as a feature (it works ok in the controller based solution) so i guess sometime in the future IAP will able to do it.
  • 5.  RE: IAP ARP Spoofing/ ARP Poisoning Question
    Posted Nov 26, 2019 09:03 AM
    Hi guys,
    I encounter the same problem.
    Regularly the IP address is not distributed to the final user.
    On the master IAP, we see the DHCP give IP address to :
    with same messages :
    [asap_firewall_forward(6665):bridge section, looking for dst bridge entry ff:ff:ff:ff:ff:ff] len 361, vlan ---, egress CP, ingress gre0:
    [asap_firewall_forward(6777):Unable to find dst bridge entry ff:ff:ff:ff:ff:ff, flood to VLAN ---] len 361, vlan ---, egress vlan , ingress gre0:
    (PS :  I have volontary hidden the vlan number)
    The only solution we found is to reboot the Master IAP.
    I see on the Master IAP the different counters incrementing:
    #show attack stats
    attack counters
    Counter Value
    arp packet counter 101368079
    drop bad arp packet counter 494
    dhcp response packet counter 17642
    With that default configuration:
    I am wondering if it could be good to disable "Drop bad ARP" and maybe "ARP poison check" too.
    What can you advice me please?
    Thanks for your answers.
  • 6.  RE: IAP ARP Spoofing/ ARP Poisoning Question
    Posted Nov 29, 2019 05:05 AM
    Hello bdealaville,
    its not the same problem, what i said is that the anti-spoofing on the IAPs was (is???) not working in same scenarios (like spoofing the gateway).
    From what you wrote you have some strange dhcp problem that increments the counters.
    I would check the dhcp lease timers and if someone doesnt have static ips or something like that.
