iAP - Captive Portal ....CERT ERROR!! - can it be done with http:// and not HTTPS:// ??
  • 1.  iAP - Captive Portal ....CERT ERROR!! - can it be done with http:// and not HTTPS:// ??
    Posted Apr 02, 2012 02:59 AM
    iAP - Captive Portal ... Clients keep - CERT ERROR!! When try to load the captive page (internal) so.. Clients saying it's not a fully working product.... (amateur method) - can it be done with http:// and not HTTPS:// ??
    Please advise.
    Thanks in advance,
    Me.
    If u would like to see the cert error - u can see the attached mp4 file (video capture of all the login process of guest..with the cert error even after installing the cert)
    Attachment(s)
    zip
    Untitled.zip   1.49 MB 1 version
  • 2.  RE: iAP - Captive Portal ....CERT ERROR!! - can it be done with http:// and not HTTPS:// ??
    Posted Apr 02, 2012 04:35 AM
    Hi!
    As far as I know you can not use http for internal captive portal and you can not upload own certificate either for this with the current release.
    You may use a remote server for captive portal authentication.
    Zsolt
