  • 1.  iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:19 AM
    Hi guys,
    I've got some issues with my iAP Setup...
    It provides two Wireless Networks, an internal one for employees (which works great) and guest access wich is behaving strange...
    It uses "Virtual Controller Assigned" Network and has a "Internal - Authenticated" Captive Portal, which also works great but only on the actual Virtual-Master AP...
    If I connect to this WiFi using any other Access-Point i get a correct IP-Address assigned (which I configured in System -> DHCP) but the Captive portal Redirect won't work :(
    And some Background Information (I suppose this is where something's wrong)
    We have multiple VLANs, for example wen use VLAN30 to manage the iAP's. That's why Virtual-Master and all the other AP's have 192.168.30.xx IP-Addresses. Employees on the internal network use 192.168.70.xx (VLAN70) and Guets use 192.168.80.xx (VLAN80). Every AP gets theese VLAN's tagged and our Core-Switch seems to route everything properly...
    Any ideas?
    Here's the config
    Spoiler
    version 6.3.1.0-4.0.0
    syslocation XXX
    virtual-controller-country XX
    virtual-controller-key XXXXX
    name "Instant AP"
    virtual-controller-ip 192.168.30.50
    virtual-controller-vlan 30 255.255.255.0 192.168.30.1
    terminal-access
    ntp-server 192.168.50.3
    clock timezone XXXX
    clock summer-time CEST recurring last sunday march 00:00 last sunday october 03:00
    rf-band all
    allow-new-aps
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    allowed-ap XX
    snmp-server community XXXX
    snmp-server host XX version 2c public inform
    arm
     wide-bands 5ghz
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode fair-access
     client-aware
     scanning
    ip dhcp pool
     subnet 192.168.80.0
     subnet-mask 255.255.255.0
     dns-server 192.168.50.3
     domain-name internal.local
     lease-time 720
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    user gast XXXX portal
    user testgast XXXX portal
    user XX XXXX radius
    user XX XXXX radius
    user XX XXXX radius
    user XX XXXX radius
    mgmt-user XX XXXX
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule InternalUser
     index 1
    wlan access-rule guestUser
     index 2
     rule 192.168.50.3 255.255.255.255 match udp 53 53 permit
     rule 192.168.80.0 255.255.255.0 match any any any permit
     rule 192.168.30.1 255.255.255.255 match any any any permit
     rule 192.168.0.0 255.255.0.0 match any any any deny
     rule 172.16.0.0 255.240.0.0 match any any any deny
     rule 10.0.0.0 255.0.0.0 match any any any deny
    wlan access-rule wired-instant
     index 3
     rule 192.168.30.51 255.255.255.255 match tcp 80 80 permit
     rule 192.168.30.51 255.255.255.255 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan ssid-profile InternalUser
     enable
     index 0
     type employee
     essid InternalUser
     wpa-passphrase XXXX
     opmode wpa-psk-tkip,wpa2-psk-aes
     max-authentication-failures 0
     vlan 70
     auth-server InternalServer
     rf-band all
     captive-portal disable
     mac-authentication
     hide-ssid
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    wlan ssid-profile guestUser
     enable
     index 1
     type guest
     essid guestUser
     opmode opensystem
     vlan guest
     rf-band all
     captive-portal internal
     dtim-period 1
    auth-survivability cache-time-out 24
    wlan captive-portal
     background-color 16750848
     banner-color 3368703
     decoded-texts terms
     redirect-url "http://www.company.tld""
     banner-text "COMPANY"
     terms-of-use "57;69;6c;6c;6b;6f;6d;6d;65;6e;20;7a;75;6d;20;56;65;72;6c;61;2d;50;68;61;72;6d;20;47;e4;73;74;65;20;57;4c;41;4e;2e;"
     use-policy "XXXX"
     authenticated
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
    wlan walled-garden
     white-list "^https?://([A-Za-z0-9.-]*\.)?COMPANY\.TLD/?"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
     wireless-containment none
    ip dhcp InternalUser
     server-type Local,L3
     server-vlan 70
     subnet 192.168.70.0
     exclude-address 192.168.70.1
     lease-time 28800
    alg
     sccp-disable
     sip-disable
     ua-disable
     vocera-disable
    wired-port-profile default_wired_port_profile
     switchport-mode access
     allowed-vlan all
     native-vlan 30
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    wired-port-profile wired-instant
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    Thanks in advance!
    #3600
  • 2.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:25 AM
    can you please upload the configuration.
    i am not able to find the configuration.
  • 3.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:32 AM
    yeah sure,
    i put it inside a spoiler in my first post but attached it additionally on this post as xxcfg.txt
    Attachment(s)
    txt
    xxcfg.txt   4 KB 1 version
  • 4.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:41 AM
    At first i would like to advice you to upgrade the IAP into the latest firmware.
    FYI.....
    http://www.arubanetworks.com/support/alerts/aruba-psa-2015-001.txt
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Security-vulnerability-advisories/td-p/176738
    If the problem still not solved let us know...
  • 5.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:52 AM
    SumaN,
    thanks for the quick reply, but it actually runs 6.3.1.8-4.0.0.8_46401 which apperas to be the latest iap firmware according to download section in aruba support portal
    (see screenshot)
  • 6.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:56 AM
    What is your model no?
    NOTE:  This is a downtime activity, if it is your production network be careful
    @gschwendti wrote:
    SumaN,
    (see screenshot)
  • 7.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 08:59 AM
    there are seven iAP-105 and one iAP-93
  • 8.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 09:04 AM
    NOTE:  Remember to take backup.
    please read the release note carefully.
  • 9.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 09:09 AM
    Ok, I wasn't sure about this because it says "early availability" which sounds like a classy word for beta :)
    I'll do that next morning beforer the heavy users are arriving and provide feedback!
  • 10.  RE: iAP Captive Portal only working on Virtual-Master-AP
    Posted Jan 28, 2015 09:24 AM
    you can go for this version also
