IAP Cellular 4G Uplink with Huawei E3276 not working
  • 1.  IAP Cellular 4G Uplink with Huawei E3276 not working
    Posted Dec 13, 2016 02:57 PM
    Hi!
    After several hours of reading posts and manuals and trying different cellular configurations without success:
    Whenever I disconnect the ethernet uplink I can see the 3G/4G probe message, but don't get a connection.
    What could be the problem with my cellular uplink?
    ISP information:
    Country: Austria
    ISP: A1
    APN: a1.net
    Username ppp@a1plus.net
    Password: ppp
    Access Number: *99#
    SIM Lock disabled
    IAP-215 Version 6.5.0.0-4.3.0.1_57133
    Cellular configuration:
    AP1_Meshportal# sh cellular conf
    Comm USB Plugged in: Vendor_ID=12d1 Product_ID=1506
    Type            Value
    4g-usb-type     huawei-cdc
    usb-type        huawei-cdc
    usb-dev         0x12d11506
    usb-tty
    usb-init        at+cgdcont=1,'IP','a1.net'
    usb-auth-type   PAP
    usb-user        ppp@a1plus.at
    usb-passwd      ppp
    usb-dial        ATDT*99#
    usb-modeswitch
    modem-isp
    modem-country
    Supported Modem Types
    Modem Type      Driver Used
    option          option
    acm             acm
    airprime        airprime
    hso             hso
    sierra-evdo     sierra-evdo
    sierra-gsm      sierra-gsm
    pantech-uml290  pantech-3g
    novatal-mc551   ether-3g
    sierra-net      sierra-net
    franklin-u770   rndis-u770
    rndis-l800      rndis-l800
    huawei-cdc      huawei-cdc
    novatel-u620    novatel-u620
    pantech-uml295  rndis-uml295
    sierra-gobi     sierra-gobi
    Supported Country list
    Country list
    China
    UK
    Germany
    India
    Supported ISP list
    ISP list
    China Unicom
    Vodafone
    T-Mobile
    Airtel
    modem status summary:USB modem attached with detect successful
    AP1_Meshportal# sh cellular stat
    Cellular Status
    card     detect     link      SIM PIN
    Present  detect-ok  Linkdown  Disable
    USB Modem Information
    Parameter      Value
    Manufacturer    HUAWEI
    Product         HUAWEI Mobile
    Serial Number
    Driver          (none)
    Vendor ID       12d1
    Product ID      1506
    cellular history log not available
    Any idea is welcome!
    Regards
    Manfred
  • 2.  RE: IAP Cellular 4G Uplink with Huawei E3276 not working
    Posted Jan 18, 2017 06:00 AM
    Hi!
    The problem is fixed now.
    With the help of the Aruba Support Team I've found the problem(s). I've made several mistakes and misunderstood some important things, but the key point was a non-working firmware of the Huawei E3276s-150 3G/4G USB Stick (but worked on my notebook...)
    Final Parameters for the Austrian Provider ‘A1 Telekom Austria’:
    AP1_Meshportal# show cellular config
    Type            Value
    4g-usb-type
    usb-type        huawei-cdc
    usb-dev         0x12d11506
    usb-tty         ttyUSB0
    usb-init        AT+CGDCONT=1,"IP","A1.net"
    usb-auth-type   PAP
    usb-passwd      ppp
    usb-dial        ATDT*99#
    usb-modeswitch
    modem-isp
    modem-country
    It would also work with the usb-type option but this is the 3G/PPPD driver.
    Details of the troubleshooting process and additional hints:
    Take care with the values of usb-init and usb-dial (APN Settings) and especially the uplink configuration and priority. To test the 3G/4G uplink it must have the highest priority (1 or 2) in relation to the eth0 and Wifi priority.
    I found a diagnostic window in the regular internet connection tool of the 3g/4G Stick under Windows with the correct provider information.
    Also try to change the usb-tty value to ttyUSB1.
    Find International APN Settings here:
    http://www.hw-group.com/products/HWg-Ares/HWg-Ares_GSM_APN_en.html
    There are 2 types of the firmware on these Huawei sticks E3276s-150:
    (you can find the correct type of your stick on a label inside the stick - there are many types out there)
    - Normal Version 21.x.x.x.x
    - HiLink Version 22.x.x.x.x
    In the beginning I had the firmware version 21.260.05.00.618 on the 3G/4G stick which did not work!
    After an upgrade to firmware version 21.491.05.00.00 (Universal) the 4G Uplink worked (found this firmware on the web - maybe it's unofficial, but it's still working also with the same dial-In tool on my notebook)
    Firmware source:
    https://routerunlock.com/download-firmware-huawei-e3276-hilink-normal-modem/
    Use unofficial firmware at your own risk - don't call me...
    I did not test the HiLink firmware - I think that there's no way back to the 'normal' 21.x.x.x.x version - I didn't want to break the stick...
    For debugging it's best to carefully examine at the output of the bootlog (console output). Believe me - you can learn a lot!
    The following commands are also helpful:
    show uplink config
    show uplink status
    show cell status
    show cell config
    show log pppd
    show log lte
    and of course:
    show tech-support
    You can find the bootlog, outputs of these commands and the output of the show tech-support and a screenshot of the settings in the GUI of my working environment attached.
    The tests have been done with the Early Deployment Release 6.5.0.0-4.3.0.1 (build 57133)
    I have tested this configuration with the General Availability Instant Release 6.4.4.8-4.2.4.5 (build 57965) also successfully.
    Good luck and Thanks to the Aruba Support Team!
    Manfred
