  • 1.  IAP ignoring Min Power Level
    Posted May 16, 2013 08:12 AM
    Customer reports poor coverage.
    There are two IAP-93 in a building, ARM is set to Min power 18, Max power unlimited.
    Howerver instants show power 14db on first and 16db on second....see screenshot
    Why is this happening?
    Notes:
    -this is 3.2.0.2. Same behaviour with 3.2.0.4
    -if I set power manualy, same behaviour.
    Thanks for your advice...
  • 2.  RE: IAP ignoring Min Power Level
    Posted May 16, 2013 08:20 AM
    Please share how do you have it configured in the ARM settings
  • 3.  RE: IAP ignoring Min Power Level
    Posted May 16, 2013 08:47 AM
    arm
     wide-bands 5ghz
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode fair-access
     scanning
    V.D.
  • 4.  RE: IAP ignoring Min Power Level
    Posted May 16, 2013 12:02 PM
    If you double click on the that particular IAP , in the radio tab it gives you the option of changing the ARM assigned or administrator assigned .
    And see you can assign it manually and if that's the case you might have to open a TAC case
  • 5.  RE: IAP ignoring Min Power Level
    Posted May 16, 2013 04:39 PM
    I had similar issue with IAP-105s initially but upgrading to firmware version 6.2.0.0-3.2.0.2_37229  corrected this problem for me.
  • 6.  RE: IAP ignoring Min Power Level
    Posted May 20, 2013 12:07 PM
    Assigning power manually didn't help.
    Well, I've finaly found where the strange power levels come from - "show log driver":
    Mon May 20 15:47:47 2013:55         10.223106 wifi0: EIRP (Config: 18.0dBm, Set: 13.0dBm, AP Max: 20.5dBm, Reg Max: 20dBm), Conducted Power Set: 10.5dBm, Gain: 2.5dBm
    So I did quick comparing to IAP-105 (now both APs are 3.3.0.x) and guess what - it is different:
    (ARM set on both APs to min/max 18/18db)
    IAP-105 :
    Mon May 20 15:34:19 2013:155       148.824448 wifi1: Country Code Set to CZ
    Mon May 20 15:34:19 2013:156       148.845601 wifi1:(3) EIRP (Config: 18.0dBm, Set: 7.5dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 5.0dBm, Gain: 2.5dBm
    Mon May 20 15:34:19 2013:157       148.845682 wifi1: Channel Set to 11 (mesh-mode: 0, state: 5)
    Mon May 20 15:34:19 2013:158       148.845728 wifi1: Internal Antenna Gain Set to 2.5 dBi for 2.4 GHz
    Mon May 20 15:34:19 2013:159       148.845771 wifi1: Internal Antenna Selected
    Mon May 20 15:34:19 2013:160       148.845810 wifi1: disabling 40Mhz
    Mon May 20 15:34:19 2013:161       148.845861 wifi1: RADIO CONFIG DONE
    Mon May 20 15:34:19 2013:162       148.845898  FREE MEMORY 71232(kB)
    Mon May 20 15:34:19 2013:163       149.040352 Refetch EIRP
    Mon May 20 15:34:19 2013:164       149.040405 wifi1:(5) EIRP (Config: 18.0dBm, Set: 18.0dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 15.5dBm, Gain: 2.5dBm
    ***  Real signal reading with INSSIDER around -25dB ***
    Compare to :IAP-92 + AP-ANT1( 3db/5db antenae, set in GUI)
    Mon May 20 15:47:47 2013:50          9.826019 wifi0: Effective External Antenna Gain Set to 2.5 dBi (connecter loss 0.5) for 2.4 GHz (Configured Value: 3.0 dBi)
    Mon May 20 15:47:47 2013:51         10.201628 wifi0: Country Code Set to CZ
    Mon May 20 15:47:47 2013:52         10.222664 wifi0: EIRP (Config: 63.5dBm, Set: 13.0dBm, AP Max: 20.5dBm, Reg Max: 20dBm), Conducted Power Set: 10.5dBm, Gain: 2.5dBm
    Mon May 20 15:47:47 2013:53         10.222796 wifi0: Channel Set to 6 (mesh-mode: 0, state: 5)
    Mon May 20 15:47:47 2013:54         10.222869 wifi0: External Antenna Selected
    Mon
    **** Signal reading in INSSIDER: -40 dB at same AP possition  ****
    Seem's that:
    1) we have a REAL problem here, signal measured on PC is lower
    2) AP92 driver code for some reason subtracts 5db (sometimes less)
