  • 1.  IAP & Mobility Controller
    Posted Dec 27, 2015 03:17 AM
    I have an installation of wifi network using 10 Alcatel-Lucent AP93 with OAW-4306G Mobility Controller. Now we want to expand the installation using Aruba IAPs. Is there a way to make the virtual controller a slave to the mobility controller (or the master). If not what would recommend as a best bractice for this type of installations.
    Thanks.
  • 2.  RE: IAP & Mobility Controller
    Posted Dec 27, 2015 07:16 AM
    Mixing Aruba and Alcatel APs is not supported.  It *might* work, but it is not tested and TAC would not provide support for them, really.
  • 3.  RE: IAP & Mobility Controller
    Posted Dec 28, 2015 04:15 PM
    OK.
    What if the mobility controller is Aruba and not Alcatel, what would you recommend ?
    I know that one solution is to convert the IAPs to campus aps but due to licence limitations, itis not possible
    NB. Alcatel-Lucent use aruba hardware (in this case 600 series) uses and software is not that different.
  • 4.  RE: IAP & Mobility Controller
    Posted Dec 28, 2015 04:17 PM
    Same situation. May work, but not supported.
  • 5.  RE: IAP & Mobility Controller
    Posted Dec 28, 2015 04:29 PM
    So the only choice is to use the new IAPs seperatly from the controller ?
  • 6.  RE: IAP & Mobility Controller
    Posted Dec 29, 2015 06:20 AM
    yes, if you want a support solution that is your only choice.
